Home » Modeling » TMF (Xtext) » Outline to be refreshed after the code refactoring(Outline to be refreshed after the code refactoring)
Outline to be refreshed after the code refactoring [message #1806769] Wed, 15 May 2019 01:26 Go to next message
I would like to update outline after code refactoring, so want to trigger refresh on outline node.
Is there a way to call refresh on outline nodes after code refactoring ?
Any class which I can refer?
Thanks and regards,
Virag Purnam
Re: Outline to be refreshed after the code refactoring [message #1806770 is a reply to message #1806769] Wed, 15 May 2019 01:32 Go to previous messageGo to next message
Doesn't that happen automatically?
If not I would consider that as bug.
(If this can be reproduced with any dsl please file a bug)
I have no idea what to do to fix it but you
May start digging at OutlineRefreshJob
Re: Outline to be refreshed after the code refactoring [message #1806772 is a reply to message #1806770] Wed, 15 May 2019 01:37 Go to previous message
Hi Mr. Christian Dietrich,
This might be due to my changes as well.
It works fine with other DSL.
I just wanted to run the outline refresh job again.
Thanks for the reply I will debug the OutlineRefreshJob.
Thanks and regards,
Virag Purnam
Previous Topic:Sharing xtext generated projects to Git causes errors in ui and ui.tests
Next Topic:Name conflicts while renaming
Current Time: Fri May 23 08:37:18 EDT 2025
Powered by FUDForum. Page generated in 0.29965 seconds
