Re: Configuring my IDE to work on Linux [message #1806844 is a reply to message #1806720] |
Thu, 16 May 2019 07:10 |
Jonathan Reznik Messages: 4 Registered: May 2019 |
I am doing okay now just running it as non-root user, but I would like to get those files moved so if I understand what your saying correctly that means somewhere in eclipse (where exactly?) I should be able to pull it up and alter the location of all those pooled files in p2 folder?
As for the other thing (the option for switching users) I thought that my post stated that I did build from source, which means that I already had to download the package at some point from the link that was provided. Anyway, I am not concerned with any special configuration that would allow a read-only user or anything like that. Just plain and simple would like to not have to use root or root folder for any part of the app so that no accidental damage occurs as a result!
My hunch is maybe if I could move this pool or bundle and have the folder in my home folder instead that it would solve my problem. So how exactly do I do that?
Edit: Put yet another way could it do any harm to make sure that the entire tree of folders under opt/eclipse where the package is currently installed has ownership and permissions set to the default system user or will that not make any bit of difference to the errors I am getting.
Here is an example of the type of errors my Eclipse is constantly displaying (literally thousands of them in the log):
java.io.FileNotFoundException: /opt/eclipse-java-2019-03/eclipse/configuration/com.genuitec.eclipse.monitor/metrics-201905--799877547.properties (Permission denied)
at java.base/java.io.FileOutputStream.open0(Native Method)
at java.base/java.io.FileOutputStream.open(FileOutputStream.java:298)
at java.base/java.io.FileOutputStream.<init>(FileOutputStream.java:237)
at java.base/java.io.FileOutputStream.<init>(FileOutputStream.java:187)
at com.genuitec.eclipse.monitor.internal.collector.client.ClientMetricsCollector.saveToFile(ClientMetricsCollector.java:151)
at com.genuitec.eclipse.monitor.internal.collector.client.ClientMetricsCollector$PeriodicalSaveJob.run(ClientMetricsCollector.java:383)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
[Updated on: Thu, 16 May 2019 07:36] Report message to a moderator
Re: Configuring my IDE to work on Linux [message #1806847 is a reply to message #1806844] |
Thu, 16 May 2019 09:06 |
Well I've gone ahead and repeated installation this time choosing the location for a pool that was different (I placed it into my Developer folder in my /home/username directory. I hope that won't conflict but seems like a better place for it than in root, which I don't understand how come that was chosen in the first place.
The installation was tricky, but it seemed to go fine.
When I fired up the new IDE, here's some little log errors I'm getting now, could someone please help me to understand? I know from working with operating systems in general it is often unrealistic to assume that no error messages will be logged, but with this particular feature is this something to be concerned about?
!ENTRY org.eclipse.mylyn.bugzilla.core 4 0 2019-05-16 01:56:02.920
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.mylyn.bugzilla.core [265]
Unresolved requirement: Require-Bundle: org.eclipse.mylyn.commons.xmlrpc; bundle-version="[3.8.0,4.0.0)"
-> Bundle-SymbolicName: org.eclipse.mylyn.commons.xmlrpc; bundle-version="3.24.2.v20180904-2231"; singleton:="true"
org.eclipse.mylyn.commons.xmlrpc [282]
Unresolved requirement: Require-Bundle: org.apache.xmlrpc; bundle-version="[3.0.0,4.0.0)"
-> Bundle-SymbolicName: org.apache.xmlrpc; bundle-version="3.0.0.v20100427-1100"
org.apache.xmlrpc [54]
Unresolved requirement: Import-Package: javax.xml.bind
at org.eclipse.osgi.container.Module.start(Module.java:452)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1784)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1763)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1726)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1657)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:233)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:343)
!ENTRY org.eclipse.mylyn.bugzilla.ui 4 0 2019-05-16 01:56:02.923
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.mylyn.bugzilla.ui [267]
Unresolved requirement: Require-Bundle: org.eclipse.mylyn.bugzilla.core; bundle-version="[3.8.0,4.0.0)"
-> Bundle-SymbolicName: org.eclipse.mylyn.bugzilla.core; bundle-version="3.24.2.v20180905-0003"; singleton:="true"
!ENTRY org.eclipse.mylyn.commons.xmlrpc 4 0 2019-05-16 01:56:02.924
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.mylyn.commons.xmlrpc [282]
!ENTRY org.eclipse.egit.core 1 0 2019-05-16 01:56:42.460
!MESSAGE Using Apache MINA sshd as ssh client.
!ENTRY org.eclipse.mylyn.tasks.core 4 0 2019-05-16 01:56:46.548
!MESSAGE Unexpected error while loading repository template extensions
!SUBENTRY 1 org.eclipse.mylyn.tasks.core 4 0 2019-05-16 01:56:46.548
!MESSAGE Could not load repository template extension contributed by 'org.eclipse.mylyn.bugzilla.ide' with connectorKind 'bugzilla'
FUDForum. Page generated in 0.08022 seconds
