Home » Newcomers » Newcomers » Non Oracle version of Java(Using alternative vendor releases of Java. )
Non Oracle version of Java [message #1806457] Thu, 09 May 2019 10:36 Go to next message
Phillip Simms is currently offline Phillip SimmsFriend
With Oracle change the licensing module for use of there Java products, this has identified possible security vulnerabilities and very high costs for the university to obtain a per user license to use Oracle Java and to obtain LTS. Are you able to advice on the functionality of the Eclipse Oxygen 4.7 software if we were to replace Oracle Java with a different Vendor. Ie; Amazon Corretto or Adapt OpenJDK. Regards Phill
Re: Non Oracle version of Java [message #1806467 is a reply to message #1806457] Thu, 09 May 2019 13:07 Go to previous messageGo to next message
I believe many people are using different JVM implementations out in a wild and I've not generally heard of any problems with doing that. But note that Eclipse Oxygen does not run with the latest version of Java, at least not without adding --add-modules=ALL-SYSTEM to the eclipse.ini.
Ed Merks
Re: Non Oracle version of Java [message #1806472 is a reply to message #1806467] Thu, 09 May 2019 13:52 Go to previous message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
To put that plainly, Oxygen is not the supported release, and it was not tested with OpenJDK builds (https://www.eclipse.org/projects/project-plan.php?planurl=http://www.eclipse.org/eclipse/development/plans/eclipse_project_plan_4_7.xml) except on RHEL7. 2019-03, based on Eclipse 4.11, is the supported release, and was tested on more platforms (https://www.eclipse.org/projects/project-plan.php?planurl=http://www.eclipse.org/eclipse/development/plans/eclipse_project_plan_4_11.xml).
Nitin Dahyabhai
Eclipse Web Tools Platform
[Updated on: Thu, 09 May 2019 13:53]
Report message to a moderator
Previous Topic:Mosquitto Websockets Help
Next Topic:git Tag prefix and its convention used in eclipse.platform
Current Time: Tue Sep 29 08:26:49 GMT 2020
Powered by FUDForum. Page generated in 0.02422 seconds
