Home » Newcomers » Newcomers » falling at the first hurdle
falling at the first hurdle [message #1806334] Tue, 07 May 2019 20:17 Go to next message
who cares is currently offline who caresFriend
I am trying to do the helloworld tutorial, and there is an error as soon as I create a java project:
Errors occurred during the build.
Errors running builder 'Java Builder' on project 'HelloWorld'.
According to similar posts, I should also paste the error log:
at org.eclipse.jdt.internal.core.builder.ClasspathJrt.addRequired(ClasspathJrt.java:326)
at org.eclipse.jdt.internal.core.builder.ClasspathJrt.selectModules(ClasspathJrt.java:320)
at org.eclipse.jdt.internal.core.builder.ClasspathJrtWithReleaseOption.getModuleNames(ClasspathJrtWithReleaseOption.java:347)
at org.eclipse.jdt.internal.core.builder.NameEnvironment.collectModuleEntries(NameEnvironment.java:397)
at org.eclipse.jdt.internal.core.builder.NameEnvironment.computeClasspathLocations(NameEnvironment.java:319)
at org.eclipse.jdt.internal.core.builder.NameEnvironment.<init>(NameEnvironment.java:62)
at org.eclipse.jdt.internal.core.builder.JavaBuilder.initializeBuilder(JavaBuilder.java:629)
at org.eclipse.jdt.internal.core.builder.JavaBuilder.build(JavaBuilder.java:174)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:833)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:220)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:263)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:316)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:319)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:371)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:392)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:154)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:244)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Re: falling at the first hurdle [message #1806348 is a reply to message #1806334] Wed, 08 May 2019 04:02 Go to previous messageGo to next message
Which version of Eclipse did you install? Which version of Java is being used in Window -> Preferences... -> Java -> Installed JREs?
I ask because these bugs sound related:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=546338
https://bugs.eclipse.org/bugs/show_bug.cgi?id=545558
You'll see in the first bug that the developers are having trouble reproducing the problem, but that they've attempted to fix it in the current development stream of JDT (aimed for the upcoming 2019-06 release)...
Re: falling at the first hurdle [message #1806751 is a reply to message #1806348] Tue, 14 May 2019 16:24 Go to previous messageGo to next message
Mark McAllister is currently offline Mark McAllisterFriend
I am having the same issue. I have installed JAVA JDK 12 and am running Eclipse 2019-03. Is there a way I can fix this?
Re: falling at the first hurdle [message #1806786 is a reply to message #1806751] Wed, 15 May 2019 07:23 Go to previous message
At this point, I think the only fix is to update to the unreleased 2019-06 version using this update site: http://download.eclipse.org/releases/2019-06
Previous Topic:Highlighting with multiple conditions in a cross tab
Next Topic:Whitespace validator in XText
Current Time: Mon Sep 16 12:34:28 GMT 2019
Powered by FUDForum. Page generated in 0.03268 seconds
