Home » Eclipse Projects » Sirius » Edge creation tool and display issue
Edge creation tool and display issue [message #1806240] Mon, 06 May 2019 17:09 Go to next message
Paul Bouche is currently offline Paul BoucheFriend
index.php/fa/35493/0/Hi,
I am using Sirius odesign files to display elements of a Capella extension viewpoints.
I am trying to create a new element called SW_Dependency which will be represented as an arrow between 2 Capella elements.
My extension's meta-model is as follows :
Data AvailabilityAssessment.data {
	Class HW_Sensitivity {
	 	extends cs.Part
	 	Attributes:
	 		SEU_Sensitivity type ecore.EFloat
	 		SEU_Detection_Duration type ecore.EInt
	 		SEU_Recovery_Duration type ecore.EInt
	 		MBU_Sensitivity type ecore.EFloat
	 		MBU_Detection_Duration type ecore.EInt
	 		MBU_Recovery_Duration type ecore.EInt
	 Class SW_Component_Dependency {
	 	Attributes:
	 		Usage_Percentage type ecore.EFloat
	 	Associations:
	 		SW_Component refers [1,1] external cs.Part
	 		HW_Component refers [1,1] external cs.Part
	 Class SW_Dependencies {
	 	extends cs.Part
	 	Attributes:
	 		ComputeAvailability type ecore.EBoolean
	 	Associations:
	 		SW_Dependency contains [0,*] SW_Component_Dependency
The diagram extension composition is as shown in Diagram_Hierarchy.PNG :
The aim here is to create an edge having the properties of a SW_Component_Dependency element connecting a Capella Deployed Behoviour PC to a Node PC (both of which are cs.Part) when clicking in a SW_Dependencies element on one end and on a Node_PC at the other end.
I have defined the following edge in my odesign file and the associated edge creation tool:
index.php/fa/35494/0/
index.php/fa/35495/0/
index.php/fa/35496/0/
index.php/fa/35497/0/
Re: Edge creation tool and display issue [message #1806452 is a reply to message #1806240] Thu, 09 May 2019 09:31 Go to previous message
Pierre-Charles David is currently offline Pierre-Charles DavidFriend
It seems there is a problem with your message, the images are not visible.
Pierre-Charles
Pierre-Charles David - Obeo
Previous Topic:SWTBot for sirius properties
Next Topic:Preview Style tooltip
Current Time: Sun Aug 09 10:07:25 GMT 2020
Powered by FUDForum. Page generated in 0.02048 seconds
