Home » Eclipse Projects » Eclipse Scout » Using PDF.js under JSP (Tomcat)(Rendeing PDF file using PDF.js)
| Using PDF.js under JSP (Tomcat) [message #1806199] |
Mon, 06 May 2019 01:58  |
Hello Andre,
Good day..
I am using PDF.js to render a pdf file, i did follow your suggestion on last post. I successfully generated a pdf file and placed it on the UI server but when i try to load and display it using pdf.js ("ClientSessionProvider.currentSession().getDesktop().openUri("pdfjs/web/viewer.html?file=test.pdf", OpenUriAction.POPUP_WINDOW)) it wont display. But when i try it on apache server it works smoothly. The scout v9.0 can not minify the pdf.js i guess, that is may be the cause of errors as stated on https://github.com/mozilla/pdf.js/issues/2479 . If you have extract time please help me out. Have a look at on these errors it might help to figure it out the problem.
2019-05-06 04:36:46,008 ERROR [qtp829149076-12] org.eclipse.scout.rt.ui.html.UiServlet - Exception while processing request -Ex: java.io.IOException: Failed running org.eclipse.scout.rt.ui.html.scriptprocessor.internal.impl.MinifyJsWithYui
at org.eclipse.scout.rt.ui.html.scriptprocessor.ScriptProcessor.runInClassLoader(ScriptProcessor.java:97)
at org.eclipse.scout.rt.ui.html.scriptprocessor.ScriptProcessor.minifyJs(ScriptProcessor.java:77)
at org.eclipse.scout.rt.ui.html.script.ScriptFileBuilder.minifyContent(ScriptFileBuilder.java:326)
at org.eclipse.scout.rt.ui.html.script.ScriptFileBuilder.compileAndMinifyContent(ScriptFileBuilder.java:307)
at org.eclipse.scout.rt.ui.html.script.ScriptFileBuilder.processLibrary(ScriptFileBuilder.java:152)
at org.eclipse.scout.rt.ui.html.script.ScriptFileBuilder.buildScript(ScriptFileBuilder.java:95)
at org.eclipse.scout.rt.ui.html.res.loader.ScriptFileLoader.loadResource(ScriptFileLoader.java:131)
at org.eclipse.scout.rt.ui.html.res.loader.AbstractResourceLoader.loadResource(AbstractResourceLoader.java:53)
at org.eclipse.scout.rt.ui.html.res.loader.ScriptFileLoader.loadResource(ScriptFileLoader.java:125)
at org.eclipse.scout.rt.ui.html.res.ResourceRequestHandler.resolveResourceFromCache(ResourceRequestHandler.java:136)
at org.eclipse.scout.rt.ui.html.res.ResourceRequestHandler.handleGet(ResourceRequestHandler.java:65)
at org.eclipse.scout.rt.ui.html.AbstractUiServletRequestHandler.handle(AbstractUiServletRequestHandler.java:26)
at org.eclipse.scout.rt.ui.html.UiServlet.handleRequestInternal(UiServlet.java:256)
at org.eclipse.scout.rt.ui.html.UiServlet.lambda$1(UiServlet.java:220)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain$Chain.continueChain(CallableChain.java:227)
at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.runTxRequiresNew(TransactionProcessor.java:100)
at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.runTxRequired(TransactionProcessor.java:129)
at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.intercept(TransactionProcessor.java:71)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain$Chain.continueChain(CallableChain.java:222)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain.call(CallableChain.java:170)
at org.eclipse.scout.rt.platform.context.RunContext.call(RunContext.java:156)
at org.eclipse.scout.rt.ui.html.UiServlet.handleRequest(UiServlet.java:220)
at org.eclipse.scout.rt.ui.html.UiServlet.doGet(UiServlet.java:152)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
at org.eclipse.scout.rt.server.commons.servlet.AbstractHttpServlet.access$0(AbstractHttpServlet.java:1)
at org.eclipse.scout.rt.server.commons.servlet.AbstractHttpServlet.wrap(AbstractHttpServlet.java:49)
at org.eclipse.scout.rt.server.commons.servlet.AbstractHttpServlet.service(AbstractHttpServlet.java:38)
at org.eclipse.scout.rt.ui.html.UiServlet.service(UiServlet.java:141)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:867)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1623)
at org.eclipse.scout.rt.server.commons.authentication.ServletFilterHelper.lambda$0(ServletFilterHelper.java:159)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at java.base/javax.security.auth.Subject.doAs(Subject.java:423)
at org.eclipse.scout.rt.server.commons.authentication.ServletFilterHelper.continueChainAsSubject(ServletFilterHelper.java:155)
at org.eclipse.scout.rt.server.commons.authentication.TrivialAccessController.handleRequest(TrivialAccessController.java:103)
at org.eclipse.scout.rt.server.commons.authentication.TrivialAccessController.handle(TrivialAccessController.java:78)
at adn.gov.ph.govservices.ui.html.UiServletFilter.doFilter(UiServletFilter.java:62)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1602)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:540)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1588)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1345)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:480)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1557)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1247)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144)
at org.eclipse.jetty.server.Server.handle(Server.java:502)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:364)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:305)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:765)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:683)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: java.lang.reflect.InvocationTargetException: null
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.scout.rt.ui.html.scriptprocessor.ScriptProcessor.runInClassLoader(ScriptProcessor.java:89)
... 67 common frames omitted
Caused by: org.mozilla.javascript.EvaluatorException: Compilation produced 971 syntax errors.
at org.eclipse.scout.rt.ui.html.scriptprocessor.internal.impl.MinifyJsWithYui$1.runtimeError(MinifyJsWithYui.java:44)
at org.mozilla.javascript.Parser.parse(Parser.java:396)
at org.mozilla.javascript.Parser.parse(Parser.java:340)
at com.yahoo.platform.yui.compressor.JavaScriptCompressor.parse(JavaScriptCompressor.java:314)
at com.yahoo.platform.yui.compressor.JavaScriptCompressor.<init>(JavaScriptCompressor.java:539)
at org.eclipse.scout.rt.ui.html.scriptprocessor.internal.impl.MinifyJsWithYui.run(MinifyJsWithYui.java:52)
... 72 common frames omitted
MDC[principal=marknovemg, httpUri=, uiSession=, clientSession=, jobName=, cid=4161ad0d-e00e-4a81-80c9-687a177722f6]
2019-05-06 04:37:00,636 INFO [qtp829149076-17] org.eclipse.scout.rt.ui.html.script.ScriptFileBuilder - Building script ScriptSource[requestPath=/pdfjs-dist/web/viewer.css, url=file:/home/mov/git/scout_v9.0/gsms-repository/govservices.ui.html/target/classes/WebContent/pdfjs-dist/web/viewer.css, fileType=STYLESHEET, nodeType=LIBRARY] theme=default m_minify=true -Ex: MDC[principal=marknovemg, httpUri=, uiSession=, clientSession=, jobName=, cid=a0260d1e-5149-4999-8fce-15edd5cd4d8b]
2019-05-06 04:37:01,351 ERROR [qtp829149076-17] org.eclipse.scout.rt.ui.html.UiServlet - Exception while processing request -Ex: java.io.IOException: Failed to parse CSS content with LESS
at org.eclipse.scout.rt.ui.html.scriptprocessor.internal.impl.CompileCssWithLess.run(CompileCssWithLess.java:30)
at org.eclipse.scout.rt.ui.html.scriptprocessor.ScriptProcessor.compileCss(ScriptProcessor.java:64)
at org.eclipse.scout.rt.ui.html.script.ScriptFileBuilder.compileContent(ScriptFileBuilder.java:317)
at org.eclipse.scout.rt.ui.html.script.ScriptFileBuilder.compileAndMinifyContent(ScriptFileBuilder.java:305)
Caused by: com.asual.lesscss.LessException: Syntax Error: Cannot read property "numerator" from undefined (line 552, column 2) near
left: -200px;
left: calc(-1 * var(--sidebar-width));
at com.asual.lesscss.compiler.RhinoCompiler.parseLessException(RhinoCompiler.java:132)
at com.asual.lesscss.compiler.RhinoCompiler.compile(RhinoCompiler.java:83)
at com.asual.lesscss.LessEngine.compile(LessEngine.java:102)
at com.asual.lesscss.LessEngine.compile(LessEngine.java:92)
at org.eclipse.scout.rt.ui.html.scriptprocessor.internal.impl.CompileCssWithLess.run(CompileCssWithLess.java:27)
Attached file is for additional information that might be helpful. Hope you can help me again..
Sincerely,
Mark
[Updated on: Mon, 06 May 2019 23:53] by Moderator
| Re: Using PDF.js under JSP (Tomcat) [message #1806257 is a reply to message #1806256] |
Tue, 07 May 2019 01:33   |
Oh my goodness, I just solved it. I just making things difficult but the answer is just right under my nose.
ClientSessionProvider.currentSession().getDesktop().openUri("http://localhost:8082/pdf/web/viewer.html?file=IntakeSheet.pdf", OpenUriAction.NEW_WINDOW);
Remarks: error during rendering process. errors are related to pdf.js
To:
ClientSessionProvider.currentSession().getDesktop().openUri("http://localhost:8082/IntakeSheet.pdf", OpenUriAction.NEW_WINDOW);
Remarks: PDF file displayed smoothly on a new webpage tab. This is without the need of pdf.js, right, since web browser itself has a built-in support for displaying pdf file.
But the best way which currently i used is by using BinaryResource which was suggested by Andre on my first post:
File pdf = new File(pathReport);
BinaryResource br = new BinaryResource(pdf.getName(), report);
ClientSessionProvider.currentSession().getDesktop().openUri(br, OpenUriAction.NEW_WINDOW);
Thanks to Andre for the help.
Sincerely,
Mark
[Updated on: Tue, 07 May 2019 04:09] by Moderator
| Re: Using PDF.js under JSP (Tomcat) [message #1810101 is a reply to message #1808173] |
Wed, 31 July 2019 01:58  |
Hello Steve,
Good day! Sorry if my reply is too late, too busy on large scout project. But if in case you still want to know my method here it is.
1.) Using JasperStudio, i created & designed my report forms ( .jrmxl format)
2.) On client side (UI), i placed all my .jrmxl files:
...ui.html/
src/
main/
resources/
/WebContent
/res *or you can create another folder to separate it to "res" folder
report1.jrxml
report2.jrxml
/temp
3.) On scout server: fill.in with data the report you want to use/generate:
public JasperPrint createReport( ... ) {
JasperPrint jasperPrint;
// create a map to pass parameters to the report
HashMap<String, Object> parameter = new HashMap<String, Object>();
try {
//Note: this setup is good only for development, it must be change on deployment because the file structure might be different.
String s = "........ui.html/src/main/resources/WebContent/pswd/jrxml_forms/IntakeSheetForm_v1.0.0.jrxml"; // provide the complete path.
JasperReport report = JasperCompileManager.compileReport(s);
// let Jasper Reports use our already defined SQL Connection
jasperPrint = JasperFillManager.fillReport(report, parameter, SQL.getConnection());
return jasperPrint;
catch (JRException e) {
throw new ProcessingException("An error occured during the creation of the report.", e);
4.) On the client side (UI) where the report generation is needed:
if( form.isFormStored() ){
byte report = BEANS.get(IFormService.class).createReport( formData );
File tmpPath = new File(".....ui.html/src/main/resources/WebContent/pswd/temp"); // Path to where the generated reports will be temporarily stored
File tmpFile;
String extension = ".pdf";
String name = "";
// get e unique temporary name
tmpFile = File.createTempFile(name, extension, tmpPath);
FileOutputStream fo = new FileOutputStream(tmpFile);
fo.write(contents);
fo.close();
// let the vm handle the deletion of the temp file
tmpFile.deleteOnExit();
File pdf = new File(tmpFile.toString());
BinaryResource bs = new BinaryResource(pdf.getName(), report);
ClientSessionProvider.currentSession().getDesktop().openUri(bs, OpenUriAction.NEW_WINDOW);
So, basically that is how I do it Steve with the help of Scout team, though it seems i might stumble on some problem (path related problem) when on production mode but i had a possible solution ready for that scenario.
If you still have some questions Steve, i will be glad to hear it :) it help me improve my understanding also.
Sincerely,
Mark
Current Time: Sat Nov 08 15:00:25 EST 2025
Powered by FUDForum. Page generated in 0.03800 seconds
