Home » Eclipse Projects » RCP Testing Tool » Unable to run test written with RCPTT 2.3 using RCPTT 2.4.1
Unable to run test written with RCPTT 2.3 using RCPTT 2.4.1 [message #1806154] Fri, 03 May 2019 20:45 Go to next message
J Cruz is currently offline J CruzFriend
When I try to run a test written with RCPTT 2.3 using RCPTT 2.4.1 the test fails with the following error:
Failed to execute org.eclipse.rcptt.core.ecl.core.model.impl.EnterContextImpl@775168bb (host: null)
Execution has timed out after 180.0 seconds
org.eclipse.core.runtime.CoreException: Execution has timed out after 180.0 seconds
at org.eclipse.rcptt.internal.launching.aut.BaseAutLaunch$TimeoutInterruption.checkInterruption(BaseAutLaunch.java:245)
at org.eclipse.rcptt.internal.launching.aut.BaseAutLaunch.computeInNewSession(BaseAutLaunch.java:277)
at org.eclipse.rcptt.internal.launching.aut.BaseAutLaunch.internalExecute(BaseAutLaunch.java:931)
at org.eclipse.rcptt.internal.launching.aut.BaseAutLaunch.execContext(BaseAutLaunch.java:601)
at org.eclipse.rcptt.internal.launching.aut.BaseAutLaunch.execElement(BaseAutLaunch.java:584)
at org.eclipse.rcptt.internal.launching.aut.BaseAutLaunch.run(BaseAutLaunch.java:560)
at org.eclipse.rcptt.internal.launching.ecl.EclContextExecutable.doExecuteContext(EclContextExecutable.java:45)
at org.eclipse.rcptt.internal.launching.ecl.EclContextExecutable.doExecute(EclContextExecutable.java:78)
at org.eclipse.rcptt.internal.launching.DataExecutable.execute(DataExecutable.java:98)
at org.eclipse.rcptt.internal.launching.Executable.executeAndRememberResult(Executable.java:127)
at org.eclipse.rcptt.internal.launching.Executable.executeAndRememberResult(Executable.java:138)
at org.eclipse.rcptt.internal.launching.Q7LaunchManager$SessionRunnable.run(Q7LaunchManager.java:147)
at org.eclipse.rcptt.internal.launching.Q7LaunchManager$ExecThread$1.run(Q7LaunchManager.java:723)
at java.base/java.lang.Thread.run(Unknown Source)
Caused by: java.util.concurrent.TimeoutException
at org.eclipse.rcptt.internal.launching.aut.BaseAutLaunch.createTimeoutStatus(BaseAutLaunch.java:298)
at org.eclipse.rcptt.internal.launching.aut.BaseAutLaunch.access$1(BaseAutLaunch.java:296)
... 14 more
In the Error log I see:
!ENTRY org.eclipse.rcptt.tesla.ecl.impl 4 123130 2019-05-03 16:09:33.790
!MESSAGE Timeout during execution of org.eclipse.rcptt.ctx.resources.WorkspaceContextProcessor$2@32086cb3
!STACK 0
java.lang.RuntimeException
at org.eclipse.rcptt.tesla.ecl.impl.UIRunnable.exec(UIRunnable.java:151)
at org.eclipse.rcptt.ctx.resources.WorkspaceContextProcessor.apply(WorkspaceContextProcessor.java:97)
at org.eclipse.rcptt.core.ContextTypeManager.apply(ContextTypeManager.java:101)
at org.eclipse.rcptt.core.internal.ecl.core.commands.EnterContextService$1.run(EnterContextService.java:45)
at org.eclipse.rcptt.core.internal.ecl.core.Utils.reportExecution(Utils.java:33)
at org.eclipse.rcptt.core.internal.ecl.core.commands.EnterContextService.service(EnterContextService.java:48)
at org.eclipse.rcptt.ecl.internal.core.AbstractSession.internalDoExecute(AbstractSession.java:83)
at org.eclipse.rcptt.ecl.internal.core.Session$1.run(Session.java:48)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:60)
Do you know what may cause this and how to fix it so older tests can run on RCPTT 2.4.1? If I run the test on RCPTT 2.3 I do not get this issue. I will note that our AUT runs on Photon.
[Updated on: Wed, 08 May 2019 18:13]
Report message to a moderator
Re: Unable to run test written with RCPTT 2.3 using RCPTT 2.4.1 [message #1807195 is a reply to message #1806154] Fri, 24 May 2019 13:15 Go to previous messageGo to next message
Marco Manalo is currently offline Marco ManaloFriend
What is the version of eclipse your application is based on? Try to update org.eclipse.rcptt.launching.ext.q7runtime to the version your working on. If you're using 2019-03 change the version to [3.5, 4.11)
Re: Unable to run test written with RCPTT 2.3 using RCPTT 2.4.1 [message #1807477 is a reply to message #1807195] Thu, 30 May 2019 19:50 Go to previous messageGo to next message
Our application is based on older version of Eclipse (Photon) not 2019-03.
Thanks for your input on this
Re: Unable to run test written with RCPTT 2.3 using RCPTT 2.4.1 [message #1821376 is a reply to message #1807477] Wed, 12 February 2020 07:17 Go to previous message
Martin Todorov is currently offline Martin TodorovFriend
I am getting same error. Runner is 2.4.3, version of AUT ist 2019-09.
Same happens with runner 2.5.0, or nightly.
When I run tests from RCPTT IDE 2.4.2 it is ok. But runner 2.4.2 is not working because of unrecognized target platform.
Previous Topic:Cannot Update AUT using maven runner (injection/test case with update)
Next Topic:Failed to execute org.eclipse.rcptt.core.ecl.core.model.impl.EnterContextImpl
Current Time: Mon Nov 04 17:33:45 GMT 2024
Powered by FUDForum. Page generated in 0.03697 seconds
