Home » Eclipse Projects » Sirius » Preview Style tooltip
Preview Style tooltip [message #1806115] Thu, 02 May 2019 21:32 Go to next message
Parsa Pourali is currently offline Parsa PouraliFriend
Hi All,
I was wondering if anyone knows any hint about how to preview a diagram as a tooltip (on mouseover). I know how to catch mouseovers or tooltips but I don't exactly know how to generate that preview! Moreover, I don't know if there a best practice for it? I can guess that one way would be to export an image of the diagram and then create a cutom tooltip to show that image to the user. Is that what the tools really do? For instance, below is an screenshot from Papyrus (I pointed on Gate C and then the tool displayed a preview of the GateC diagram) . I need something similar to this.
index.php/fa/35451/0/
Parsa
[Updated on: Thu, 02 May 2019 21:33]
Report message to a moderator
Re: Preview Style tooltip [message #1806455 is a reply to message #1806115] Thu, 09 May 2019 09:51 Go to previous message
Pierre-Charles David is currently offline Pierre-Charles DavidFriend
It looks like the code used by Papyrus is here: https://git.eclipse.org/r/plugins/gitiles/papyrus/org.eclipse.papyrus/+/master/plugins/infra/core/org.eclipse.papyrus.infra.core.sasheditor/src/org/eclipse/papyrus/infra/core/sasheditor/internal/ImageToolTipManager.java
They are able to do this because all the Papyrus diagrams are opened (and rendered) inside a single editor, so when showing Gate_A, the SWT control for diagram Gate_C is available and can render into an image. This technique will not work with Sirius as each diagram has its own editor which may not be opened. You can however produce images of your diagrams using the org.eclipse.sirius.ui.business.api.dialect.DialectUIServices.exportWithResult(DRepresentation, Session, IPath, ExportFormat, IProgressMonitor) method and then use the image from that file as tooltip.
Pierre-Charles
Pierre-Charles David - Obeo
Previous Topic:Edge creation tool and display issue
Next Topic:Issue on adding meta model - Add from registry is not showing packages.
Current Time: Sat Jul 11 19:03:16 GMT 2020
Powered by FUDForum. Page generated in 0.01593 seconds
