Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » open62541 version used in forte-1.10.2(With open62541 version actually is used in forte-1.10.2 release?)
open62541 version used in forte-1.10.2 [message #1806108] Thu, 02 May 2019 17:30 Go to next message
Felipe Adriano is currently offline Felipe AdrianoFriend
Member
I have tried build forte-1.10.2 but open62541 module does not build. In forte-1.9.1 I used the master of open62541 repository, but with forte-1.10.2 this don't work anymore.
Re: open62541 version used in forte-1.10.2 [message #1806112 is a reply to message #1806108] Thu, 02 May 2019 19:38 Go to previous messageGo to next message
Kirill Dorofeev is currently offline Kirill DorofeevFriend
Member
Hi Felipe,
since 1.10.x we've agreed that we should stick to the releases of the open62541 stack. This is well documented here. Please, try to checkout open62541 stack release (tag 'v0.3.0') and compile forte with it. If the problem persists, could you please attach the log to see what else could go wrong.
Hope this helps,
Kirill
Re: open62541 version used in forte-1.10.2 [message #1806152 is a reply to message #1806112] Fri, 03 May 2019 16:28 Go to previous message
Member
Thanks by the help, I was using the old documentation that indicated the use of master from open62541 repo.
Now using the branch 0.3.0 everything is Ok!
Previous Topic:Error in fboot when there are seven publish or subscribe block using SFP
Next Topic:QX block - "FB Not Initialized"
Current Time: Thu Jan 21 22:27:50 GMT 2021
Powered by FUDForum. Page generated in 0.02024 seconds
