Home » Eclipse Projects » Sirius » Getting java.lang.IllegalArgumentException: Argument not valid exception
Getting java.lang.IllegalArgumentException: Argument not valid exception [message #1805868] Fri, 26 April 2019 04:59 Go to next message
Nagashree KN is currently offline Nagashree KNFriend
I am using sirius and xtext combination. on saving the contents in xtext editor, elements are being created in sirius diagram but arrangeall is not happening and i am getting exception like -
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.IllegalArgumentException: Argument not valid)
at org.eclipse.swt.SWT.error(SWT.java:4533)
at org.eclipse.swt.SWT.error(SWT.java:4448)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:185)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4211)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3827)
at org.eclipse.ui.internal.dialogs.EventLoopProgressMonitor.runEventLoop(EventLoopProgressMonitor.java:125)
at org.eclipse.ui.internal.dialogs.EventLoopProgressMonitor.worked(EventLoopProgressMonitor.java:186)
at org.eclipse.core.runtime.SubMonitor$RootInfo.worked(SubMonitor.java:305)
at org.eclipse.core.runtime.SubMonitor.done(SubMonitor.java:661)
at org.eclipse.ui.internal.SaveableHelper.doSaveModel(SaveableHelper.java:433)
at org.eclipse.ui.internal.SaveableHelper$3.run(SaveableHelper.java:202)
at org.eclipse.ui.internal.SaveableHelper$5.run(SaveableHelper.java:286)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:437)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:353)
at org.eclipse.ui.internal.WorkbenchWindow$14.run(WorkbenchWindow.java:2184)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2180)
at org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOperation(SaveableHelper.java:294)
at org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOperation(SaveableHelper.java:272)
at org.eclipse.ui.internal.SaveableHelper.saveModels(SaveableHelper.java:214)
at org.eclipse.ui.internal.SaveableHelper.savePart(SaveableHelper.java:149)
at org.eclipse.ui.internal.WorkbenchPage.saveSaveable(WorkbenchPage.java:3904)
at org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPage.java:3918)
at org.eclipse.ui.internal.handlers.SaveHandler.execute(SaveHandler.java:54)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:295)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:282)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:264)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:494)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:488)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.executeCommand(KeyBindingDispatcher.java:286)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.press(KeyBindingDispatcher.java:507)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.processKeyEvent(KeyBindingDispatcher.java:558)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.filterKeySequenceBindings(KeyBindingDispatcher.java:378)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.access$0(KeyBindingDispatcher.java:324)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher$KeyDownFilter.handleEvent(KeyBindingDispatcher.java:86)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1270)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1078)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1103)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1088)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1130)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1126)
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1547)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:4918)
at org.eclipse.swt.widgets.Canvas.WM_CHAR(Canvas.java:364)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4799)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:359)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5110)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2552)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3822)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Caused by: java.lang.IllegalArgumentException: Argument not valid
at org.eclipse.swt.SWT.error(SWT.java:4514)
at org.eclipse.swt.SWT.error(SWT.java:4419)
at org.eclipse.swt.graphics.GC.setFont(GC.java:4617)
at org.eclipse.draw2d.FigureUtilities.setFont(FigureUtilities.java:363)
at org.eclipse.draw2d.FigureUtilities.getTextDimension(FigureUtilities.java:93)
at org.eclipse.draw2d.FigureUtilities.getTextExtents(FigureUtilities.java:140)
at org.eclipse.gmf.runtime.draw2d.ui.figures.WrappingLabel$MapModeConstants.getEllipseTextSize(WrappingLabel.java:191)
at org.eclipse.gmf.runtime.draw2d.ui.figures.WrappingLabel.getTruncationStringSize(WrappingLabel.java:998)
at org.eclipse.gmf.runtime.draw2d.ui.figures.WrappingLabel.getMinimumSize(WrappingLabel.java:913)
at org.eclipse.gmf.runtime.draw2d.ui.figures.WrappingLabel.calculateSizes(WrappingLabel.java:744)
at org.eclipse.gmf.runtime.draw2d.ui.figures.WrappingLabel.layout(WrappingLabel.java:721)
at org.eclipse.draw2d.Figure.validate(Figure.java:1899)
at org.eclipse.draw2d.Figure.validate(Figure.java:1901)
at org.eclipse.gmf.runtime.diagram.ui.figures.ResizableCompartmentFigure.validate(ResizableCompartmentFigure.java:474)
at org.eclipse.gmf.runtime.diagram.ui.figures.BorderedNodeFigure.validate(BorderedNodeFigure.java:262)
at org.eclipse.gmf.runtime.diagram.ui.figures.BorderItemsAwareFreeFormLayer.validate(BorderItemsAwareFreeFormLayer.java:183)
at org.eclipse.gmf.runtime.diagram.ui.editparts.DiagramEditPart$1.validate(DiagramEditPart.java:157)
at org.eclipse.gmf.runtime.diagram.ui.commands.DeferredLayoutCommand$1.run(DeferredLayoutCommand.java:150)
at org.eclipse.gmf.runtime.diagram.ui.util.EditPartUtil.synchronizeRunnableToMainThread(EditPartUtil.java:111)
at org.eclipse.gmf.runtime.diagram.ui.commands.DeferredLayoutCommand.doExecuteWithResult(DeferredLayoutCommand.java:186)
at org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTransactionalCommand.doExecute(AbstractTransactionalCommand.java:247)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.gmf.runtime.diagram.ui.commands.ICommandProxy.execute(ICommandProxy.java:68)
at org.eclipse.gef.commands.CompoundCommand.execute(CompoundCommand.java:129)
at org.eclipse.sirius.diagram.ui.internal.refresh.layout.SiriusCanonicalLayoutCommand.executeLayoutDueToExternalChanges(SiriusCanonicalLayoutCommand.java:107)
at org.eclipse.sirius.diagram.ui.internal.refresh.layout.SiriusCanonicalLayoutCommand.access$3(SiriusCanonicalLayoutCommand.java:104)
at org.eclipse.sirius.diagram.ui.internal.refresh.layout.SiriusCanonicalLayoutCommand$1.run(SiriusCanonicalLayoutCommand.java:90)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:182)
... 79 more
FYI : I am not using Embedded xtext editor in Sirius diagram.
Can any one help in resolving this issue.
Thanks!
Re: Getting java.lang.IllegalArgumentException: Argument not valid exception [message #1805877 is a reply to message #1805868] Fri, 26 April 2019 09:52 Go to previous message
Laurent Fasani is currently offline Laurent FasaniFriend
Hello
A lead could be to understand why setFont raises an error?
It could be that the font does not exist. But in that case the issue should be reproducible independently from combining xtext and sirius
Laurent
Laurent Fasani - Obeo
Previous Topic:Add viewpoint to Sirius server and use it
Next Topic:Programmatically exporting image from aird in stand-alone situation
Current Time: Sun Jan 19 08:29:28 GMT 2020
Powered by FUDForum. Page generated in 0.01474 seconds
