Home » Eclipse Projects » Sirius » Loading Resource file
Loading Resource file [message #1805856] Thu, 25 April 2019 15:34 Go to next message
Andrius S is currently offline Andrius SFriend
Hello, we are trying to create a resource from DSL, to run VIATRA query engine and get the matched patterns. We are getting the error: " Cannot create a resource for 'file:/test.mydsl'; a registered resource factory is needed. What is missing?
		File modelPath = new File( "test.mydsl");
	 	URI fileURI = URI.createFileURI(modelPath.getAbsolutePath());
	 	System.out.println(fileURI);
		Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("xml", new ResourceFactoryImpl());
	 	Resource r = new ResourceFactoryImpl().createResource(fileURI);
		ResourceSet resourceSet = new ResourceSetImpl();
		r = resourceSet.getResource(fileURI, true);
//		Resource resource = resourceSet.getResource(fileURI, true);
		final StringBuilder results = new StringBuilder();
		if (r != null) {
				ViatraQueryEngine engine = ViatraQueryEngine.on(new EMFScope(r));
				Matcher matcher = Matcher.on(engine);
				Collection<viatra.Assets.Match> matches = matcher.getAllMatches();
				for (IPatternMatch match : matches) {
					results.append(match.prettyPrint()+"; ");
				if(matches.size() == 0) {
					results.append("Empty match set");
				results.append("\n");
				// using a match processor
		} else {
			System.out.println("bleh");
Re: Loading Resource file [message #1805880 is a reply to message #1805856] Fri, 26 April 2019 11:58 Go to previous messageGo to next message
Laurent Fasani is currently offline Laurent FasaniFriend
Hello
First you have to register your file extension:
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put(<your file extension>, new XMIResourceFactoryImpl());
You can use XMIResourceFactoryImpl if you don't have your own factory.
In your case <your file extension>= "mydsl"
Then when creating the resource from a ResourceSet, EMF will find the factory from the Registry
So you just have to write the code below
ResourceSetImpl rs = new ResourceSetImpl();
Resource r = rs.createResource(fileURI);
Laurent
Laurent Fasani - Obeo
Re: Loading Resource file [message #1805884 is a reply to message #1805880] Fri, 26 April 2019 12:48 Go to previous message
If *.mydsl is an Xtext DSL you should invoke MyDSLStandaloneSetup.doSetUp() to do the injector-based factory registration.
Regrads
Ed Willink
Previous Topic:Programmatically exporting image from aird in stand-alone situation
Next Topic:Style customization not working
Current Time: Tue Aug 04 06:25:39 GMT 2020
Powered by FUDForum. Page generated in 0.01427 seconds
