Home » Eclipse Projects » Jubula » Can the jubula project be managed by GIT
Can the jubula project be managed by GIT [message #1805785] Wed, 24 April 2019 03:43 Go to next message
Li Huan is currently offline Li HuanFriend
Hello, our team wants to write test cases by jubula ITE together on different machines. Can the jubula project be managed by GIT ? If not, how can we write together?
Re: Can the jubula project be managed by GIT [message #1806376 is a reply to message #1805785] Wed, 08 May 2019 09:19 Go to previous message
Marcel Hein is currently offline Marcel HeinFriend
yes and no. The Jubula ITE uses a Database (see: https://help.eclipse.org/oxygen/index.jsp?topic=%2Forg.eclipse.jubula.client.ua.help%2Fcontent%2Fhtml%2FuserManual%2Ftasks%2Fch03s22s02.html).
You can of course work together on the same project but the ITE does not provide a way to track or diff changes or work on different branches (you can do this by creating multiple projects). See : https://help.eclipse.org/neon/index.jsp?topic=%2Forg.eclipse.jubula.client.ua.help%2Fcontent%2Fhtml%2FuserManual%2Findex.html
If you require these specific GIT functions you can use the Jubula API: https://help.eclipse.org/oxygen/index.jsp?topic=%2Forg.eclipse.jubula.client.ua.help%2Fcontent%2Fhtml%2FdeveloperManual%2FclientAPI%2Fch02s03.html
The Jubula API can be used with a testing framework such as JUnit. As these tests are written as java code you can of course git to manage your tests.
Previous Topic:What is exactly Jubula license ?
Next Topic:Jubula with .bat AUT
Current Time: Fri Aug 07 16:11:16 GMT 2020
Powered by FUDForum. Page generated in 0.01389 seconds
