Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Error when complie the forte in ubuntu
Error when complie the forte in ubuntu [message #1805714] Mon, 22 April 2019 14:36 Go to next message
Barry wan is currently offline Barry wanFriend
Member
Hi, everyone,
I have an error when compling the forte in ubuntu.
First, I build the forte project using CMAKE. and using make command in posix directory。
So, how to fix it?
thank you!
Re: Error when complie the forte in ubuntu [message #1805723 is a reply to message #1805714] Mon, 22 April 2019 18:21 Go to previous messageGo to next message
Alois Zoitl is currently offline Alois ZoitlFriend
I see that you have the FORTE_COM_MUXSER activated. It looks like that this one makes an issue. Do you need multiplexed serial communication? If not I would recommend to deactivate it.
Alois
Re: Error when complie the forte in ubuntu [message #1805737 is a reply to message #1805723] Tue, 23 April 2019 00:37 Go to previous messageGo to next message
Member
dear Alois,
thank you for your apply. it works by deselecting the FORTE_COM_MUXSER.
cheers,
barry
Re: Error when complie the forte in ubuntu [message #1805761 is a reply to message #1805737] Tue, 23 April 2019 09:46 Go to previous message
you are welcome Barry.
I created a bug report [1] to keep track of this issue.
cheers,
Alois
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=546652
Previous Topic:Error with TCP/IP example
Next Topic:How to change the font type and size in 4DIAC editors?
Current Time: Mon Jan 18 02:01:28 GMT 2021
Powered by FUDForum. Page generated in 0.02000 seconds
