Home » Eclipse Projects » Jubula » OpenJDK 11 support
Re: OpenJDK 11 support [message #1805788 is a reply to message #1805774] |
Wed, 24 April 2019 05:52   |
Marvin Mueller Messages: 255 Registered: March 2012 |
Is it really the same problem as written in your first Post? If this is the case, the embedded Autagent should show the same Problems. Maybe you used the wrong Autagent..
Is there anything in the rc_javafx.log or client.log or autagent.log which might be from interest? (If there are other internal Information included we can find an other way)
Jubula runs with java 8 in Standard and it is totally okay to start applications which are using newer Java Versions (I did also test this that way)
I am unsure why your custom plugins are not working. Maybe they need some minor adjustments(like Version ranges). If these are extensions for custom components this might explain why you can not map these components.
best regards
Marvin
[Updated on: Wed, 24 April 2019 05:54] Report message to a moderator
Re: OpenJDK 11 support [message #1805869 is a reply to message #1805788] |
Fri, 26 April 2019 06:56   |
Jakub Foltas Messages: 6 Registered: April 2019 |
Hello again,
sorry for the delayed anwer, I have been rather busy lately. I have tried the same process and checked the jubula log folder for more information. Perhaps this will be of some use.
1. Running my application as AUT from Jubula (8.7.1.046, with default jubula.ini settings, so the used jre is the one in my jubula installation path) manages to start the AUT. The application uses mostly standard javafx components and some customized ones, but neither of them are recognized during the object mapping. No highlighting etc. During this two errors are logged to client.log:
2019-04-26 08:19:30.364 [Connection.ReaderThread:Socket[addr=/127.0.0.1,port=60228,localport=60001]] ERROR o.e.j.autagent.OsgiAUTStartHelper - No bundle found for ID 'com.thoughtworks.xstream'.
2019-04-26 08:19:30.364 [Connection.ReaderThread:Socket[addr=/127.0.0.1,port=60228,localport=60001]] ERROR o.e.j.autagent.OsgiAUTStartHelper - No bundle found for ID 'org.xmlpull'.
and to rc_javafx.log:
2019-04-26 08:18:27.936 [Connection.ReaderThread:Socket[addr=JFOLTASW10.indra.es/192.168.226.60,port=60187,localport=60237]] ERROR o.e.j.c.internal.Communicator - caught exception from 'org.eclipse.jubula.rc.common.commands.ChangeAUTModeCommand.execute()'
java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.jubula.rc.javafx.components.CurrentStages
at org.eclipse.jubula.rc.javafx.JavaFXAUTServer.removeToolkitEventListener(JavaFXAUTServer.java:121) ~[org.eclipse.jubula.rc.javafx_7.0.2.201902270829.jar:na]
at org.eclipse.jubula.rc.javafx.JavaFXAUTServer.removeToolkitEventListener(JavaFXAUTServer.java:103) ~[org.eclipse.jubula.rc.javafx_7.0.2.201902270829.jar:na]
at org.eclipse.jubula.rc.common.AUTServer.setMode(AUTServer.java:955) ~[org.eclipse.jubula.rc.common_7.0.2.201902270829.jar:na]
at org.eclipse.jubula.rc.common.commands.ChangeAUTModeCommand.execute(ChangeAUTModeCommand.java:103) ~[org.eclipse.jubula.rc.common_7.0.2.201902270829.jar:na]
at org.eclipse.jubula.communication.internal.Communicator$ConnectionListener.received(Communicator.java:921) ~[org.eclipse.jubula.communication_4.0.0.201902270829.jar:na]
at org.eclipse.jubula.communication.internal.connection.Connection.fireMessageReceived(Connection.java:402) ~[org.eclipse.jubula.communication_4.0.0.201902270829.jar:na]
at org.eclipse.jubula.communication.internal.connection.Connection.access$2(Connection.java:391) ~[org.eclipse.jubula.communication_4.0.0.201902270829.jar:na]
at org.eclipse.jubula.communication.internal.connection.Connection$ReaderThread.run(Connection.java:454) ~[org.eclipse.jubula.communication_4.0.0.201902270829.jar:na]
2019-04-26 08:20:25.316 [Connection.ReaderThread:Socket[addr=JFOLTASW10.indra.es/192.168.226.60,port=60187,localport=60259]] ERROR o.e.j.c.internal.Communicator - caught exception from 'org.eclipse.jubula.rc.common.commands.ChangeAUTModeCommand.execute()'
2. When I run the same application from cmd by using autagent. Basically I run the autagent.exe from the *jubula 8.7.1 installation path*/ite and then a bat file containing
autrun.exe -javafx -i "VDT_RUT_A" -w "C:\Users\jfoltas\Desktop\client_trunk_for_jubula" -e "C:\Users\jfoltas\Desktop\client_trunk_for_jubula\run_OTEDVDT_openJdk.bat"
which is the same as the settings configured in Jubula project. This time the application does not start, nothing goes to any of the jubula logs. The following is the full stacktrace from cmd:
C:\Program Files\jubula_8.7.1.046\ite>autrun.exe -javafx -i "VDT_RUT_A" -w "C:\Users\jfoltas\Desktop\client_trunk_for_jubula" -e "C:\Users\jfoltas\Desktop\client_trunk_for_jubula\run_OTEDVDT_openJdk.bat"
AUTs sysout:
AUTs sysout: C:\Users\jfoltas\Desktop\client_trunk_for_jubula>"C:\Program Files\Java\jdk-11.0.2\bin\java" -cp "IntradayMarket.jar" com.indra.market.client.Main_Java11 --ote.server.url=https://otd-market:9443/IndraMarketServer/CommonServlet --ote.log.level=ALL --ote.log.timestamp=1 --add-opens=javafx.controls/javafx.scene.control.skin=ALL-UNNAMED-illegal-access=permit
AUTs syserr: Picked up _JAVA_OPTIONS: "-javaagent:C:\Program Files\jubula_8.7.1.046\ite\plugins\org.eclipse.jubula.rc.common.agent_7.0.2.201902270829.jar"
AUTs syserr: SLF4J: Class path contains multiple SLF4J bindings.
AUTs syserr: SLF4J: Found binding in [jar:file:/C:/Users/jfoltas/Desktop/client_trunk_for_jubula/IntradayMarket.jar!/org/slf4j/impl/StaticLoggerBinder.class]
AUTs syserr: SLF4J: Found binding in [jar:file:/C:/Program%20Files/jubula_8.7.1.046/ite/plugins/ch.qos.logback.slf4j_1.0.7.v201505121915.jar!/org/slf4j/impl/StaticLoggerBinder.class]
AUTs syserr: SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
AUTs sysout: 08:27:25,310 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Could NOT find resource [logback.groovy]
AUTs sysout: 08:27:25,310 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Could NOT find resource [logback-test.xml]
AUTs syserr: SLF4J: Actual binding is of type [ch.qos.logback.classic.util.ContextSelectorStaticBinder]
AUTs sysout: 08:27:25,310 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Found resource [logback.xml] at [jar:file:/C:/Program%20Files/jubula_8.7.1.046/ite/plugins/org.eclipse.jubula.rc.javafx_7.0.2.201902270829.jar!/logback.xml]
AUTs sysout: 08:27:25,310 |-WARN in ch.qos.logback.classic.LoggerContext[default] - Resource [logback.xml] occurs multiple times on the classpath.
AUTs sysout: 08:27:25,310 |-WARN in ch.qos.logback.classic.LoggerContext[default] - Resource [logback.xml] occurs at [jar:file:/C:/Program%20Files/jubula_8.7.1.046/ite/plugins/org.eclipse.jubula.rc.javafx_7.0.2.201902270829.jar!/logback.xml]
AUTs sysout: 08:27:25,310 |-WARN in ch.qos.logback.classic.LoggerContext[default] - Resource [logback.xml] occurs at [jar:file:/C:/Users/jfoltas/Desktop/client_trunk_for_jubula/IntradayMarket.jar!/logback.xml]
AUTs sysout: 08:27:25,342 |-INFO in ch.qos.logback.core.joran.spi.ConfigurationWatchList@117e949d - URL [jar:file:/C:/Program%20Files/jubula_8.7.1.046/ite/plugins/org.eclipse.jubula.rc.javafx_7.0.2.201902270829.jar!/logback.xml] is not of type file
AUTs sysout: 08:27:25,482 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - debug attribute not set
AUTs sysout: 08:27:25,498 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
AUTs sysout: 08:27:25,514 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [STDOUT]
AUTs sysout: 08:27:25,576 |-INFO in ch.qos.logback.core.joran.action.NestedComplexPropertyIA - Assuming default type [ch.qos.logback.classic.encoder.PatternLayoutEncoder] for [encoder] property
AUTs sysout: 08:27:25,654 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.rolling.RollingFileAppender]
AUTs sysout: 08:27:25,654 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [FILE]
AUTs sysout: 08:27:25,670 |-INFO in ch.qos.logback.core.rolling.FixedWindowRollingPolicy@6db9f5a4 - Will use zip compression
AUTs sysout: 08:27:25,685 |-INFO in ch.qos.logback.core.joran.action.NestedComplexPropertyIA - Assuming default type [ch.qos.logback.classic.encoder.PatternLayoutEncoder] for [encoder] property
AUTs sysout: 08:27:25,685 |-INFO in ch.qos.logback.core.rolling.RollingFileAppender[FILE] - Active log file name: C:\Users\jfoltas/.jubula/logs/rc_javafx.log
AUTs sysout: 08:27:25,685 |-INFO in ch.qos.logback.core.rolling.RollingFileAppender[FILE] - File property is set to [C:\Users\jfoltas/.jubula/logs/rc_javafx.log]
AUTs sysout: 08:27:25,685 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.rolling.RollingFileAppender]
AUTs sysout: 08:27:25,685 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [CAP-FILE]
AUTs sysout: 08:27:25,685 |-INFO in ch.qos.logback.core.rolling.FixedWindowRollingPolicy@5f8edcc5 - Will use zip compression
AUTs sysout: 08:27:25,685 |-INFO in ch.qos.logback.core.rolling.RollingFileAppender[CAP-FILE] - Active log file name: C:\Users\jfoltas/.jubula/logs/rc_javafx_ExecutedCaps.log
AUTs sysout: 08:27:25,685 |-INFO in ch.qos.logback.core.rolling.RollingFileAppender[CAP-FILE] - File property is set to [C:\Users\jfoltas/.jubula/logs/rc_javafx_ExecutedCaps.log]
AUTs sysout: 08:27:25,685 |-INFO in ch.qos.logback.classic.joran.action.RootLoggerAction - Setting level of ROOT logger to WARN
AUTs sysout: 08:27:25,685 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [FILE] to Logger[ROOT]
AUTs sysout: 08:27:25,685 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [CAP] to DEBUG
AUTs sysout: 08:27:25,685 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting additivity of logger [CAP] to false
AUTs sysout: 08:27:25,685 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [CAP-FILE] to Logger[CAP]
AUTs sysout: 08:27:25,685 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - End of configuration.
AUTs sysout: 08:27:25,685 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@7b02881e - Registering current configuration as safe fallback point
AUTs sysout:
AUTs syserr: Exception in thread "Start AUT Server" java.lang.ExceptionInInitializerError
AUTs syserr: at org.eclipse.jubula.rc.javafx.listener.ComponentHandler.<init>(ComponentHandler.java:94)
AUTs syserr: at org.eclipse.jubula.rc.javafx.JavaFXAUTServer.addToolkitEventListeners(JavaFXAUTServer.java:97)
AUTs syserr: at org.eclipse.jubula.rc.common.AUTServer.addToolKitEventListenerToAUT(AUTServer.java:860)
AUTs syserr: at org.eclipse.jubula.rc.common.AUTServer.startAUT(AUTServer.java:430)
AUTs syserr: at org.eclipse.jubula.rc.common.commands.AUTStartCommand.execute(AUTStartCommand.java:57)
AUTs syserr: at org.eclipse.jubula.rc.common.AUTServer$3.run(AUTServer.java:499)
AUTs syserr: Caused by: java.lang.NullPointerException
AUTs syserr: at com.sun.javafx.tk.quantum.QuantumToolkit.resumeTimer(QuantumToolkit.java:512)
AUTs syserr: at com.sun.javafx.tk.quantum.QuantumToolkit$PulseTask.set(QuantumToolkit.java:203)
AUTs syserr: at com.sun.javafx.tk.quantum.QuantumToolkit.setAnimationRunnable(QuantumToolkit.java:883)
AUTs syserr: at com.sun.javafx.tk.quantum.MasterTimer.postUpdateAnimationRunnable(MasterTimer.java:105)
AUTs syserr: at com.sun.scenario.animation.AbstractMasterTimer$MainLoop.updateAnimationRunnable(AbstractMasterTimer.java:324)
AUTs syserr: at com.sun.scenario.animation.AbstractMasterTimer.addPulseReceiver(AbstractMasterTimer.java:176)
AUTs syserr: at javafx.animation.Animation.addPulseReceiver(Animation.java:148)
AUTs syserr: at javafx.animation.Animation.startReceiver(Animation.java:154)
AUTs syserr: at javafx.animation.Animation.play(Animation.java:913)
AUTs syserr: at org.eclipse.jubula.rc.javafx.components.CurrentStages.<clinit>(CurrentStages.java:102)
AUTs syserr: ... 6 more
AUTs syserr: Exception in thread "WindowsNativeRunloopThread" java.lang.NoSuchMethodError: <init>
AUTs syserr: at com.sun.glass.ui.win.WinApplication.staticScreen_getScreens(Native Method)
AUTs syserr: at com.sun.glass.ui.Screen.initScreens(Screen.java:412)
AUTs syserr: at com.sun.glass.ui.Application.lambda$run$1(Application.java:152)
AUTs syserr: at com.sun.glass.ui.win.WinApplication._runLoop(Native Method)
AUTs syserr: at com.sun.glass.ui.win.WinApplication.lambda$runLoop$3(WinApplication.java:174)
AUTs syserr: at java.base/java.lang.Thread.run(Thread.java:834)
AUTs syserr: Exception in thread "JavaFX Application Thread" java.lang.NullPointerException
AUTs syserr: at com.sun.prism.d3d.D3DPipeline.getAdapterOrdinal(D3DPipeline.java:205)
AUTs syserr: at com.sun.javafx.tk.quantum.QuantumToolkit.assignScreensAdapters(QuantumToolkit.java:738)
AUTs syserr: at com.sun.javafx.tk.quantum.QuantumToolkit.runToolkit(QuantumToolkit.java:334)
AUTs syserr: at com.sun.javafx.tk.quantum.QuantumToolkit.lambda$startup$10(QuantumToolkit.java:279)
AUTs syserr: at com.sun.glass.ui.Application.lambda$run$1(Application.java:153)
Maybe there might be some significance in the way we pack our application, the application is defined as maven project and the openjavafx is added as dependency and packed along with everything into a fat jar when build. Then in order to run with java11 the workaround of calling "proxy Main" is currently being used (see https://stackoverflow.com/questions/52569724/javafx-11-create-a-jar-file-with-gradle/52571719#52571719). Could this be the problem?
Jakub
[Updated on: Fri, 26 April 2019 07:43] Report message to a moderator
Current Time: Sun May 22 16:39:44 GMT 2022
Powered by FUDForum. Page generated in 0.02762 seconds
