Home » Eclipse Projects » Eclipse Platform » Multiple versions of an extension
Multiple versions of an extension [message #335635] Fri, 17 April 2009 08:57 Go to next message
Originally posted by: spanprevention-nursubscriptions.gmail.com
Requirement is as follows:
Plugin A defines an extension point. Plugin B provides the corresponding
extension. There are however, multiple versions of Plugin B. The
requirement is that all these versions should be available through the
extension point mechanism.
I have only been able to obtain the latest version of the plugin through
the extension point APIs ( IExtensionPoint.getExtensions(); )
Any pointers or suggestions are greatly appreciated.
TIA,
Best Regards,
- abhi
Re: Multiple versions of an extension [message #335638 is a reply to message #335635] Fri, 17 April 2009 10:36 Go to previous messageGo to next message
Abhi,
Plugins that contribute extensions must be singletons and while many
versions of such a plugin may exist, only the one that satisfies the
version range dependencies of the other installed plugins will be
activated while the rest will be as if they aren't there at all.
abhi wrote:
> corresponding extension. There are however, multiple versions of
> Plugin B. The requirement is that all these versions should be
> available through the extension point mechanism.
> through the extension point APIs ( IExtensionPoint.getExtensions(); )
> TIA,
> Best Regards,
> - abhi
Ed Merks
Re: Multiple versions of an extension [message #335640 is a reply to message #335635] Fri, 17 April 2009 13:04 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
It's as Ed mentioned, plugins that deal with the registry can only be
singletons. There is an enhancement open you can add yourself to,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=108211
PW
Paul Webster
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/workbench.htm
Previous Topic:Cascading build processes triggered by resource modification
Next Topic:Custom folder compare
Current Time: Tue Apr 16 15:05:59 GMT 2024
Powered by FUDForum. Page generated in 2.69426 seconds
