Home » Modeling » TMF (Xtext) » Name conflicts while renaming(Name conflicts comes up while renaming only for previous elements)
Name conflicts while renaming [message #1805122] Mon, 08 April 2019 04:47 Go to next message
Virag Purnam is currently offline Virag PurnamFriend
I am facing issue in rename.
When I try to rename element and put the new name which is already present previous to the place where rename has been triggered, it shows the name conflicts.
But when I try to rename element and put new name which is already present after the place where rename has been triggered, it does not show the name conflicts and rename happens successfully.
I have created a small example to explain that.
Grammar:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals hidden(WS, ML_COMMENT, SL_COMMENT, TEST_STMT)
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model:
	conts+=Cont* procs+=Proc*;
Cont:
	'Cont' name=ID '{' items+=Item* '}' ;
Item: 'Item' name=ID;
Proc:
	'Link' item1=[Item|ID] 'OF' con1=[Cont|ID] 'TO' item2=[Item|ID] 'OF' con2=[Cont|ID]
//Test  statement
terminal TEST_STMT :  'FreeText: ' ->  '.';
Sample Model:
Cont container1 {
	Item item1
Cont container2 {
	Item item2
Link item1 OF container1 TO item2 OF container2
In the above example, when i try to rename "container2" to "container1", it shows name conflicts. But it does not show name conflicts when I try to rename "container1" to "container2".
According to me it should throw error (name conflicts) for both the cases.
How can i achieve this?
Could you please help me with this regard.
Thanks and regards,
Virag Purnam
Re: Name conflicts while renaming [message #1805124 is a reply to message #1805122] Mon, 08 April 2019 05:10 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Sounds like https://github.com/eclipse/xtext-eclipse/issues/124
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/xtext/
Twitter : @chrdietrich
Re: Name conflicts while renaming [message #1805125 is a reply to message #1805124] Mon, 08 April 2019 05:23 Go to previous messageGo to next message
Hi Mr. Christian Dietrich,
Yes, I am facing the same issue.
Is there solution available?
if not, when can we expect the fix?
Thanks and regards,
Virag Purnam
Re: Name conflicts while renaming [message #1805126 is a reply to message #1805125] Mon, 08 April 2019 05:27 Go to previous messageGo to next message
what about providing a fix. or take care it is provided
Re: Name conflicts while renaming [message #1805127 is a reply to message #1805125] Mon, 08 April 2019 05:29 Go to previous messageGo to next message
Can we override and modify class "RefactoringCrossReferenceSerializer.java"?
In method "getCrossRefText", we can check the new name for duplication among available elements.
Thanks and regards,
Virag Purnam
Re: Name conflicts while renaming [message #1805128 is a reply to message #1805127] Mon, 08 April 2019 05:30 Go to previous messageGo to next message
you can override and customize everything.
Re: Name conflicts while renaming [message #1805129 is a reply to message #1805128] Mon, 08 April 2019 05:32 Go to previous messageGo to next message
Ok. I will give a try.
Thanks and regards,
Virag Purnam
Re: Name conflicts while renaming [message #1806768 is a reply to message #1805129] Wed, 15 May 2019 05:14 Go to previous messageGo to next message
I have done code changes in RefactoringCrossReferenceSerializer class to check the duplicate name. I have attached code here.
Do you see any side effect of this code change?
Your comments will be helpful.
Thanks and regards,
Virag Purnam
import static org.eclipse.ltk.core.refactoring.RefactoringStatus.ERROR;
import static org.eclipse.ltk.core.refactoring.RefactoringStatus.WARNING;
import java.util.ArrayList;
import java.util.List;
import org.apache.log4j.Logger;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.EReference;
import org.eclipse.xtext.CrossReference;
import org.eclipse.xtext.GrammarUtil;
import org.eclipse.xtext.conversion.IValueConverterService;
import org.eclipse.xtext.conversion.ValueConverterException;
import org.eclipse.xtext.linking.impl.LinkingHelper;
import org.eclipse.xtext.naming.IQualifiedNameConverter;
import org.eclipse.xtext.resource.IEObjectDescription;
import org.eclipse.xtext.scoping.IScope;
import org.eclipse.xtext.scoping.IScopeProvider;
import org.eclipse.xtext.serializer.tokens.SerializerScopeProviderBinding;
import org.eclipse.xtext.ui.refactoring.impl.RefactoringCrossReferenceSerializer;
import org.eclipse.xtext.ui.refactoring.impl.StatusWrapper;
import org.eclipse.xtext.ui.refactoring.impl.RefactoringCrossReferenceSerializer.RefTextEvaluator;
import org.eclipse.xtext.util.ITextRegion;
import org.eclipse.xtext.xbase.lib.IterableExtensions;
import com.google.inject.Inject;
public class CustomRefactoringCrossReferenceSerializer extends RefactoringCrossReferenceSerializer {
	private static final Logger log = Logger.getLogger(CustomRefactoringCrossReferenceSerializer.class);
	@Inject
	@SerializerScopeProviderBinding
	private IScopeProvider scopeProvider;
	@Inject
	private IValueConverterService valueConverter;
	@Inject
	private LinkingHelper linkingHelper;
	@Inject
	private IQualifiedNameConverter qualifiedNameConverter;
	public String getCrossRefText(EObject owner, CrossReference crossref, EObject target,
			RefTextEvaluator refTextEvaluator, ITextRegion linkTextRegion, StatusWrapper status) {
		try {
			final EReference ref = GrammarUtil.getReference(crossref, owner.eClass());
			final IScope scope = scopeProvider.getScope(owner, ref);
			if (scope == null) {
				throw new IllegalStateException("Could not create scope for the given cross reference.");
			String ruleName = linkingHelper.getRuleNameFrom(crossref);
			 *  Code added here
			// Getting all elements in the scope
			Iterable<IEObjectDescription> allElements = scope.getAllElements();
			List<String> names = new ArrayList<>();
			// Check for duplicate names after refactoring
			for(IEObjectDescription desc : allElements) {
				String unconvertedRefText = qualifiedNameConverter.toString(desc.getName());
				String convertedRefText = valueConverter.toString(unconvertedRefText, ruleName);
				if(names.contains(convertedRefText)) {
					return null;
				} else {
					names.add(convertedRefText);
			 *  Ends here
			Iterable<IEObjectDescription> descriptionsForCrossRef = scope.getElements(target);
			String bestRefText = null;
			List<String> badNames = new ArrayList<String>();
			for (IEObjectDescription desc : descriptionsForCrossRef) {
				try {
					if (refTextEvaluator.isValid(desc) && (bestRefText == null || refTextEvaluator.isBetterThan(convertedRefText, bestRefText)))
						bestRefText = convertedRefText;
				} catch (ValueConverterException e) {
					// this is a problem only if we don't find any matching value
					badNames.add(desc.getName().toString());
			if (bestRefText == null && !badNames.isEmpty()) {
				status.add(WARNING,
						"Misconfigured language: New reference text has invalid syntax. Following names are in the scope: " + IterableExtensions.join(badNames, ", "), owner, linkTextRegion);
			return bestRefText;
		} catch (Exception exc) {
			log.error(exc.getMessage(), exc);
			status.add(ERROR, exc.getMessage(), owner, linkTextRegion);
			return null;
Re: Name conflicts while renaming [message #1806771 is a reply to message #1806768] Wed, 15 May 2019 05:35 Go to previous messageGo to next message
Have no time to look at sry
Re: Name conflicts while renaming [message #1806773 is a reply to message #1806771] Wed, 15 May 2019 05:40 Go to previous messageGo to next message
Ok.
Thanks and regards,
Virag Purnam
Re: Name conflicts while renaming [message #1806774 is a reply to message #1806773] Wed, 15 May 2019 05:55 Go to previous messageGo to next message
Tamas Miklossy is currently offline Tamas MiklossyFriend
Member
@Virag Purnam: Could you please try to convert your suggesstion into a Pull Request attached to the issue https://github.com/eclipse/xtext-eclipse/issues/124 ? It would really help us to review your change.
Re: Name conflicts while renaming [message #1806776 is a reply to message #1806774] Wed, 15 May 2019 06:25 Go to previous message
Hi Mr. Tamas Miklossy,
I will do that.
Thanks and regards,
Virag Purnam
Previous Topic:Outline to be refreshed after the code refactoring
Next Topic:Dealing with cross-reference instances
Current Time: Mon Feb 24 13:03:17 GMT 2020
Powered by FUDForum. Page generated in 0.02035 seconds
