Can't understand why one rule are recognized as another [message #1804963] |
Wed, 03 April 2019 20:33 |
kozhaev Vladimir Messages: 108 Registered: July 2009 |
Hi all, I have the grammar(see it below) it's simplified variant of some bigger.
And two peases of code
In this one everything is fine
class user {}
query q2() = (user,user) @ { } ;
As well as in this:
Quote:class user {}
query q2() = (u:user) @ { } ;
But in this one, I have the problem
class user {}
query q2() = (user) @ { } ;
I assume it because the first part of AtOperator is recognized as a tuple value. But I need the tuple value in my grammar.
So, how to fix my grammar?
Vladimir
grammar org.blockchain.rell.Rell with org.eclipse.xtext.common.Terminals
generate rell "http://www.blockchain.org/rell/Rell"
Model:
entities+=ClassDefinition*
operations+=Query*;
ClassDefinition:
'class' name=ID LEFT_BRACE
attributeListField+=AttributeListField*
RIGHT_BRACE;
AttributeListField:
mutable=Mutable? key=Key? index=Index? attributeList+=RelAttrubutesList ';';
Query:
"query" name=ID LEFT_BRACKET parameters=RelAttrubutesList? RIGHT_BRACKET
(DOUBLE_QUOTE type=TypeReference)?
((ASSIGNMENT returnExr=Expression ';') |
(LEFT_BRACE
statements+=Statement*
(('return' returnExr=Expression ';')?)
RIGHT_BRACE));
Statement:
(relation=Relational | methodCall=DotValue) ';';
Variable:
name=VariableDeclaration ((ASSIGNMENT expression=Expression)?);
Relational:
AtOperator;
AtOperator:
(tableNameWithAlias+=TableNameWithAlias |
(LEFT_BRACKET
tableNameWithAlias+=TableNameWithAlias (',' tableNameWithAlias+=TableNameWithAlias)*
RIGHT_BRACKET))
Ampersand
(ampersandModificator=AmpersandModificator?)
LEFT_BRACE
(ASSIGNMENT? conditions+=Expression (',' ASSIGNMENT? conditions+=Expression)*)?
RIGHT_BRACE
(tupleValue=TupleValue?);
TupleValue:
LEFT_BRACKET members+=TupleValueMember (',' tuplePart+=TupleValueMember)* RIGHT_BRACKET;
TupleValueMember:
(name=ValuableID ASSIGNMENT)? value=Expression;
TableNameWithAlias:
classRefDecl=ClassRefDecl |
justNameDecl=JustNameDecl;
ClassRefDecl:
name=ID DOUBLE_QUOTE classDef=[ClassDefinition];
JustNameDecl:
name=[ClassDefinition];
VariableDeclarationRef:
name=[VariableDeclaration|ValuableID];
AccessToList:
LEFT_SQUARE_BRACE expr=Expression RIGHT_SQUARE_BRACE;
Expression:
or=Or;
Or returns Expression:
And ({Or.left=current} "or" right=And)*;
And returns Expression:
Equality ({And.left=current} "and" right=Equality)*;
Equality returns Expression:
Comparison ({Equality.left=current} op=EQUALS
right=Comparison)*;
Comparison returns Expression:
PlusOrMinus ({Comparison.left=current} op=IN
right=PlusOrMinus)*;
PlusOrMinus returns Expression:
MulOrDiv (({Plus.left=current} PlusChar | {Minus.left=current} MinusChar)
right=MulOrDiv)*;
MulOrDiv returns Expression:
Primary ({MulOrDiv.left=current} op=(MulChar)
right=Primary)*;
Primary returns Expression:
prefixChar=MinusChar expression=Primary |
DotValue;
DotValue:
(LEFT_BRACKET DotValue RIGHT_BRACKET) | ((atom=Atomic (accesToList=AccessToList?) (DOT dotPart=DotValue)?));
Atomic returns Expression:
{SelectOp} value=AtOperator
| {TupleRes} value=TupleValue
| {VariableDeclarationRef} value=VariableDeclarationRef;
RelAttrubutesList:
value+=Variable (',' value+=Variable)*;
VariableDeclaration:
name=ValuableID ((DOUBLE_QUOTE type=TypeReference)?);
TypeReference:
type=PrimitiveType;
PrimitiveType:
Text;
ValuableID:
PrimitiveType | ID;
AmpersandModificator:
PlusChar | MulChar | QuestionChar;
Text:
'text';
Key:
'key';
Index:
'index';
Mutable:
'mutable';
Ampersand:
QuestionChar:
PlusChar:
MinusChar:
MulChar:
terminal IN:
'in';
terminal RIGHT_SQUARE_BRACE:
terminal LEFT_SQUARE_BRACE:
terminal RIGHT_BRACE:
terminal LEFT_BRACE:
terminal RIGHT_BRACKET:
terminal LEFT_BRACKET:
terminal ASSIGNMENT:
terminal EQUALS:
terminal DOUBLE_QUOTE:
terminal DOT:
Re: Can't understand why one rule are recognized as another [message #1804965 is a reply to message #1804963] |
Wed, 03 April 2019 20:45 |
error(211): ../org.xtext.example.mydsl1/src-gen/org/xtext/example/mydsl1/parser/antlr/internal/InternalMyDsl.g:486:3: [fatal] rule ruleStatement has non-LL(*) decision due to recursive rule invocations reachable from alts 1,2. Resolve by left-factoring or using syntactic predicates or using backtrack=true option.
error(211): ../org.xtext.example.mydsl1/src-gen/org/xtext/example/mydsl1/parser/antlr/internal/InternalMyDsl.g:1723:2: [fatal] rule ruleDotValue has non-LL(*) decision due to recursive rule invocations reachable from alts 1,2. Resolve by left-factoring or using syntactic predicates or using backtrack=true option.
=> did you enable backtracking?
=> you really should solve the left recursion an ambiguities there
Twitter : @chrdietrich
[Updated on: Wed, 03 April 2019 20:56] Report message to a moderator
FUDForum. Page generated in 0.04663 seconds
