HelloWorld Scout 9 not working [message #1804924] |
Wed, 03 April 2019 11:37 |
The Maddes Messages: 44 Registered: October 2018 |
Member |
Hey Guys,
so i wanted to migrate my Scout 8 Project to Scout 9.
I did the things described in the Migration guide and then i got some Errors.
So i thought fine, maybe i skipped something important and started a fresh helloworld project of scout 9 and i got the same Error.
If it is important i use Eclipse Scout Version 2019-03(4.11.0).
The Properties of the pom.xml (helloworld) :
<parent>
<groupId>org.eclipse.scout</groupId>
<artifactId>maven_rt_plugin_config-master</artifactId>
<version>3.1.0</version>
<relativePath></relativePath>
</parent>
<groupId>org.eclipse.scout.apps</groupId>
<artifactId>helloworld</artifactId>
<version>1.0.0-SNAPSHOT</version>
<packaging>pom</packaging>
<name>My Application Parent Module</name>
<properties>
<org.eclipse.scout.apps.helloworld.version>${project.version}</org.eclipse.scout.apps.helloworld.version>
<jdk.source.version>1.8</jdk.source.version>
<org.eclipse.scout.rt.version>9.0.0.009_Simrel_2019_03</org.eclipse.scout.rt.version>
</properties>
And here is the Error:
2019-04-03 13:19:52,692 ERROR [scout-platform-starter] org.eclipse.scout.rt.platform.internal.PlatformImplementor.start(PlatformImplementor.java:144) - Error during platform startup - MDC[]
java.lang.NoClassDefFoundError: org/jboss/jandex/IndexView
at org.eclipse.scout.rt.platform.inventory.ClassInventory.<clinit>(ClassInventory.java:36)
at org.eclipse.scout.rt.platform.internal.PlatformImplementor.createBeanManager(PlatformImplementor.java:215)
at org.eclipse.scout.rt.platform.internal.PlatformImplementor.start(PlatformImplementor.java:133)
at org.eclipse.scout.rt.platform.internal.PlatformStarter.run(PlatformStarter.java:30)
Caused by: java.lang.ClassNotFoundException: org.jboss.jandex.IndexView
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
... 4 common frames omitted
Exception in thread "scout-platform-starter" java.lang.NoClassDefFoundError: org/jboss/jandex/IndexView
... 4 more
2019-04-03 13:19:52,695 WARN [main] org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:554) - Failed startup of context o.e.s.d.j.P_WebAppContext@15bfd87{My Application Server,/,file:///C:/Dev/Projects/ScoutTest/helloworld/helloworld.server.app.dev/src/main/webapp/,UNAVAILABLE} - MDC[]
org.eclipse.scout.rt.platform.exception.PlatformException: The platform is in an invalid state.
at org.eclipse.scout.rt.platform.internal.PlatformImplementor.throwOnPlatformInvalid(PlatformImplementor.java:94)
at org.eclipse.scout.rt.platform.internal.PlatformImplementor.awaitPlatformStarted(PlatformImplementor.java:84)
at org.eclipse.scout.rt.server.commons.WebappEventListener.contextInitialized(WebappEventListener.java:47)
at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:957)
at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:552)
at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:922)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:364)
at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1497)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1459)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:852)
at org.eclipse.jetty.servlet.ServletContextHandler.doStart(ServletContextHandler.java:278)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:545)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:138)
at org.eclipse.jetty.server.Server.start(Server.java:415)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:108)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:113)
at org.eclipse.jetty.server.Server.doStart(Server.java:382)
at org.eclipse.scout.dev.jetty.JettyServer.start(JettyServer.java:95)
at org.eclipse.scout.dev.jetty.JettyServer.main(JettyServer.java:56)
2019-04-03 13:19:52,714 INFO [main] org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:292) - Started ServerConnector@c540f5a{HTTP/1.1,[http/1.1]}{0.0.0.0:8080} - MDC[]
Exception in thread "main" org.eclipse.scout.rt.platform.exception.PlatformException: The platform is in an invalid state.
Thank you for your advice in advance.
FUDForum. Page generated in 0.04274 seconds
