DSML Diagram. Weird behaviour of Delete Selected Element [message #1804816] |
Mon, 01 April 2019 16:41 |
Simon Kuzin Messages: 18 Registered: February 2019 Location: Singapore |
Dear all,
I'm observing pretty weird behaviour of "Delete Selected Element" on custom DSML diagram.
In short words, uml model element is getting deleted , but diagram shape does not.
The same behaviour is observed in my custom diagram type as for standard uml class as for my custom prototyped element.
On standard UML Class Diagram "Delete Selected Element" deletes uml element and shape normally as for standard uml class as for my custom prototyped element.
I suppose some configuration is done wrong for my architecture or typedefs, however cannot figure out a problem.
Could you please advise on possible causes or suggest a direction for further investigation.
Case Screen Recording
Code of my DSML attached.
When "Delete Selected Element" engaged on my DSML diagram, following exceptions are getting risen:
!ENTRY org.eclipse.papyrus.infra.properties.ui 1 0 2019-04-02 00:09:50.240
!MESSAGE [DEBUG] "Profile application"
!ENTRY org.eclipse.papyrus.uml.profile 4 0 2019-04-02 00:13:18.856
!MESSAGE Unexpected Error
!STACK 0
org.eclipse.papyrus.infra.core.services.ServiceNotFoundException: Can't find the ResourceSet needed retrieve the ServiceRegistry.
at org.eclipse.papyrus.infra.emf.utils.ServiceUtilsForResource.getServiceRegistry(ServiceUtilsForResource.java:65)
at org.eclipse.papyrus.infra.emf.utils.ServiceUtilsForEObject.getServiceRegistry(ServiceUtilsForEObject.java:45)
at org.eclipse.papyrus.infra.emf.utils.ServiceUtilsForEObject.getServiceRegistry(ServiceUtilsForEObject.java:1)
at org.eclipse.papyrus.infra.core.utils.AbstractServiceUtils.getTransactionalEditingDomain(AbstractServiceUtils.java:77)
at org.eclipse.papyrus.uml.properties.profile.ui.compositesformodel.AppliedStereotypeCompositeOnModel.getEditingDomain(AppliedStereotypeCompositeOnModel.java:78)
at org.eclipse.papyrus.uml.properties.profile.ui.compositesformodel.AppliedStereotypeCompositeOnModel.dispose(AppliedStereotypeCompositeOnModel.java:716)
at org.eclipse.papyrus.uml.properties.profile.ui.compositesformodel.DecoratedTreeComposite$LocalDisposeListener.widgetDisposed(DecoratedTreeComposite.java:590)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:127)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4363)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1512)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1535)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1516)
at org.eclipse.swt.widgets.Widget.release(Widget.java:1353)
at org.eclipse.swt.widgets.Control.release(Control.java:2962)
at org.eclipse.swt.widgets.Composite.releaseChildren(Composite.java:957)
at org.eclipse.swt.widgets.Widget.release(Widget.java:1356)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:694)
at org.eclipse.papyrus.infra.properties.ui.runtime.DefaultDisplayEngine.disposeControls(DefaultDisplayEngine.java:167)
at org.eclipse.papyrus.infra.properties.ui.runtime.DefaultDisplayEngine.getTabDescriptors(DefaultDisplayEngine.java:136)
at org.eclipse.papyrus.infra.properties.ui.xwt.XWTTabDescriptorProvider.getTabDescriptors(XWTTabDescriptorProvider.java:146)
at org.eclipse.ui.internal.views.properties.tabbed.view.TabbedPropertyRegistry.getTabDescriptors(TabbedPropertyRegistry.java:282)
at org.eclipse.ui.views.properties.tabbed.TabbedPropertySheetPage.setInput(TabbedPropertySheetPage.java:745)
at org.eclipse.ui.views.properties.tabbed.TabbedPropertySheetPage.selectionChanged(TabbedPropertySheetPage.java:571)
at org.eclipse.papyrus.infra.ui.editor.MultiDiagramPropertySheetPage.selectionChanged(MultiDiagramPropertySheetPage.java:118)
at org.eclipse.ui.views.properties.PropertySheet.showSelectionAndDescription(PropertySheet.java:508)
at org.eclipse.ui.views.properties.PropertySheet.selectionChanged(PropertySheet.java:488)
at org.eclipse.ui.internal.e4.compatibility.SelectionService.notifyListeners(SelectionService.java:242)
at org.eclipse.ui.internal.e4.compatibility.SelectionService.handlePostSelectionChanged(SelectionService.java:116)
at org.eclipse.ui.internal.e4.compatibility.SelectionService.lambda$2(SelectionService.java:71)
at org.eclipse.e4.ui.internal.workbench.SelectionAggregator$3.run(SelectionAggregator.java:163)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.e4.ui.internal.workbench.SelectionAggregator.notifyPostListeners(SelectionAggregator.java:160)
at org.eclipse.e4.ui.internal.workbench.SelectionAggregator.access$7(SelectionAggregator.java:158)
at org.eclipse.e4.ui.internal.workbench.SelectionAggregator$6.lambda$0(SelectionAggregator.java:250)
at org.eclipse.e4.core.contexts.RunAndTrack.runExternalCode(RunAndTrack.java:59)
at org.eclipse.e4.ui.internal.workbench.SelectionAggregator$6.changed(SelectionAggregator.java:250)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:117)
at org.eclipse.e4.core.internal.contexts.EclipseContext.processScheduled(EclipseContext.java:365)
at org.eclipse.e4.core.internal.contexts.EclipseContext.set(EclipseContext.java:380)
at org.eclipse.e4.ui.internal.workbench.SelectionServiceImpl.setPostSelection(SelectionServiceImpl.java:39)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.lambda$2(CompatibilityPart.java:130)
at org.eclipse.papyrus.infra.core.sasheditor.internal.eclipsecopy.MultiPageSelectionProvider$1.run(MultiPageSelectionProvider.java:117)
at org.eclipse.papyrus.infra.core.sasheditor.internal.eclipsecopy.MultiPageSelectionProvider.fireEventChange(MultiPageSelectionProvider.java:113)
at org.eclipse.papyrus.infra.core.sasheditor.internal.eclipsecopy.MultiPageSelectionProvider.firePostSelectionChanged(MultiPageSelectionProvider.java:107)
at org.eclipse.papyrus.infra.core.sasheditor.internal.eclipsecopy.MultiPageEditorSite.handlePostSelectionChanged(MultiPageEditorSite.java:573)
at org.eclipse.papyrus.infra.core.sasheditor.internal.eclipsecopy.MultiPageEditorSite$2.selectionChanged(MultiPageEditorSite.java:476)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalViewer.flushSelectionEvents(DiagramGraphicalViewer.java:256)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalViewer$1.run(DiagramGraphicalViewer.java:234)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:40)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:185)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4102)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1173)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:566)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:155)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:661)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:597)
at org.eclipse.equinox.launcher.Main.run(Main.java:1476)
at org.eclipse.equinox.launcher.Main.main(Main.java:1449)
!ENTRY org.eclipse.ui 4 0 2019-04-02 00:13:18.857
!MESSAGE Unhandled event loop exception
!STACK 0
!ENTRY org.eclipse.papyrus.infra.properties.ui 1 0 2019-04-02 00:13:18.881
[Updated on: Mon, 01 April 2019 16:43] Report message to a moderator
FUDForum. Page generated in 0.02742 seconds
