Home » Newcomers » Newcomers » Windows Subsystem for Linux and Terminal View(Is there a way to using WSL for terminal view instead of cmd)
Windows Subsystem for Linux and Terminal View [message #1804767] Sun, 31 March 2019 22:26 Go to next message
Chris Maggiulli is currently offline Chris MaggiulliFriend
I am running Eclipse Neon 3 on my Windows 10 laptop. I have Windows Subsystem for Linux installed which gives me access to a bash terminal. The bash terminal can be launched by executing C:\Windows\System32\bash.exe.
I assume the terminal view in Eclipse launches C:\Windows\System32\cmd.exe inside a panel in the IDE. I am wondering if there is any place that location is set, as I would like to switch to bash.exe instead.
If this is not exposed as a configuration is this something that can be overridden with a plugin? It would be a nice introductory project for me
Re: Windows Subsystem for Linux and Terminal View [message #1804775 is a reply to message #1804767] Mon, 01 April 2019 06:08 Go to previous messageGo to next message
Does this question relate to yours?
https://stackoverflow.com/questions/44220993/how-to-run-system-shell-terminal-inside-eclipse
Have you hunted through the preferences to see if this is configurable?
Sorry I don't really know how this is implemented or what is supported. I think you are using this project:
https://www.eclipse.org/tm/
And I think this is their forum (according to the preference link):
https://www.eclipse.org/forums/index.php/f/210/
Ed Merks
Re: Windows Subsystem for Linux and Terminal View [message #1804808 is a reply to message #1804775] Mon, 01 April 2019 14:50 Go to previous messageGo to next message
Thank you for the reply. The StackOverflow post doesn't quite address my question. I have attached a screenshot of the plugin I am speaking of. I believe it is part of the Eclipse core, not a marketplace plugin. What level of certainty are you that this is TM plugin? Thanks!
  • Attachment: 8U1Fg.png
    (Size: 77.35KB, Downloaded 63 times)
[Updated on: Mon, 01 April 2019 14:52]
Report message to a moderator
Re: Windows Subsystem for Linux and Terminal View [message #1804820 is a reply to message #1804808] Mon, 01 April 2019 18:32 Go to previous message
The plug-in spy can help answer questions like this, i.e., Alt-Shift-F1 will tell you which plug-in contributes the current view and from that namespace you should be able to figure how who (which project) is contributing that.
Ed Merks
Previous Topic:Eclipse Langou change to german not work
Next Topic:Add reference Eclipse acute??eclipse 2018-03
Current Time: Fri Sep 25 20:00:54 GMT 2020
Powered by FUDForum. Page generated in 0.03376 seconds
