[Acceleo] Problems migrating a project from Acceleo 3.7.3/Java 9.0.4 to Acceleo 3.7.8/Java 11.0.2 [message #1804736] |
Sat, 30 March 2019 19:36  |
Hello experts
I hope you can help me. I want to migrate an existing Acceleo project developed using Eclipse Photon/Acceleo 3.7.3/Java 9.0.4 to a different environment, Eclipse 2019-03/Acceleo 3.7.8/Java SDK 11.0.2. I tried the following:
1. I imported the existing Acceleo 3.7.3 project into the new environment's workspace using Import ... -> General -> Existing Projects Into Workspace. The creation of the project's files into the target workspace was successful, but I had different building problems in the Error Log console.
2. I created a new project in Eclipse 2019-03/Acceleo 3.7.8 and copied the contents of the only .mtl file in the Eclipse Photon/Acceleo 3.7.3 project into the corresponding .mtl file in the new project. This time, I got the following building errors:
MESSAGE: Errors running builder 'Acceleo Builder' on project 'org.eclipse.acceleo.module.firstSwiftGen'.
EXCEPTION STACK TRACE:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.UnresolvedReferenceException: Unresolved reference '/0/name.1'. (platform:/resource/org.eclipse.acceleo.module.firstSwiftGen/bin/org/eclipse/acceleo/module/firstSwiftGen/main/swiftGen.emtl, 310, 72)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.acceleo.common.utils.ModelUtils.load(ModelUtils.java:391)
at org.eclipse.acceleo.common.utils.ModelUtils.load(ModelUtils.java:356)
at org.eclipse.acceleo.internal.ide.ui.builders.runner.CreateRunnableAcceleoOperation.run(CreateRunnableAcceleoOperation.java:129)
at org.eclipse.acceleo.internal.ide.ui.builders.AcceleoBuilder.build(AcceleoBuilder.java:213)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:833)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:220)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:263)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:316)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:319)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:371)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:392)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:154)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:244)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Caused by: org.eclipse.emf.ecore.xmi.UnresolvedReferenceException: Unresolved reference '/0/name.1'. (platform:/resource/org.eclipse.acceleo.module.firstSwiftGen/bin/org/eclipse/acceleo/module/firstSwiftGen/main/swiftGen.emtl, 310, 72)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardReferences(XMLHandler.java:1197)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHandler.java:1282)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endDocument(AbstractSAXParser.java:746)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:539)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:888)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:824)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1216)
at java.xml/com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:635)
at java.xml/com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:324)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
at org.eclipse.acceleo.model.mtl.resource.EMtlResourceImpl.doLoad(EMtlResourceImpl.java:93)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1563)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1342)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 17 more
and
MESSAGE: Problems occurred when invoking code from plug-in: "org.eclipse.core.resources".
... 17 more
Does any of you know what I am doing wrong? Thank you very much in advance.
/TB
FUDForum. Page generated in 0.02237 seconds
