Home » Eclipse Projects » Sirius » Show only parent nodes.
Show only parent nodes. [message #1804450] Tue, 26 March 2019 10:36 Go to next message
Bushra Harraq is currently offline Bushra HarraqFriend
in the follwing the metamodel constellation is documented:
http://prntscr.com/n32fnd
To get all the Processes:
aql: self.process
Now, I want to show all node, which don't have a parent Process. Here is my approach, which does not work. Please correct me.
aql: self.process -> select(myProcess | myProcess.eInverse(subProcesses) -> size = 0)
Thank you,
Bushra
[Updated on: Tue, 26 March 2019 13:12]
Report message to a moderator
Re: Show only parent nodes. [message #1804476 is a reply to message #1804450] Tue, 26 March 2019 14:28 Go to previous message
Maxime Porhel is currently offline Maxime PorhelFriend
Hi Bushra,
The AQL documentation can be found here: https://www.eclipse.org/acceleo/documentation/
There are several eInverse method with or without parameters:
- eInverse() (no parameter) : returns any element which as a relationship with the current one
- eInverse(packageName::EClassName) : returns only instances of the given type.
- eInverse('featureName') : more explicit and query for a specific reference name
Please also note that
- -> isEmpty is equivalent to -> size() = 0
- the opposites would be myEelement.ref1.ref2 -> size() <> 0 or not (myElement.ref1.ref2 -> isEmpty())
In your case, you should try:
aql: self.process -> select(myProcess | myProcess.eInverse('subProcesses') -> isEmpty())
Maxime Porhel - Obeo
Join the Sirius community at SiriusCon. Register for free: Nov. 9th Paris
http://www.siriuscon.org/
Previous Topic:Integrating sirius into xtext
Next Topic:Automatic creation diagram
Current Time: Tue Apr 07 13:04:17 GMT 2020
Powered by FUDForum. Page generated in 0.01981 seconds
