Home » Eclipse Projects » Jubula » AUT with Java 11
AUT with Java 11 [message #1804397] Mon, 25 March 2019 12:52 Go to next message
Christoph Steinforth is currently offline Christoph SteinforthFriend
Hi there,
we are testing one of our application with JUBULA. When we start our application wih a JRE 8, everything is working. When we switch the undelying JVM to e.g. JAVA 11, the AUT is not starting anymore, the application simply crashes . Are there any log messages where we can find some additional information about the reason for this, or is there no support (or not yet) for AUT running under > JAVA 8?
Thanks in advance,
Christoph
Re: AUT with Java 11 [message #1804432 is a reply to message #1804397] Tue, 26 March 2019 05:47 Go to previous messageGo to next message
Marvin Mueller is currently offline Marvin MuellerFriend
Hello Christoph,
Log messages are located in your HOME_DIRECTORY/.jubula/logs . But I assume it is because of the modularization after Java 9. From our release notes:
Java 9 and later
Java 9 and later applications must be started with the jvm arguments '--add-opens=javafx.controls/javafx.scene.control.skin=ALL-UNNAMED-illegal-access=permit'. This is necessary because we are using internal information to get e.g. some position information of components.
best regards
Marvin Mueller
Re: AUT with Java 11 [message #1804504 is a reply to message #1804432] Wed, 27 March 2019 13:25 Go to previous messageGo to next message
Hi Marvin,
thanks for your quick answer. Do we have to add the jvm argument
to our own application, or this to be added to the eclipse.ini?
Thanks in advance,
Christoph
Re: AUT with Java 11 [message #1804828 is a reply to message #1804504] Tue, 02 April 2019 05:39 Go to previous message
This is for the Application which should be tested
Previous Topic:JCommandButton cannot be mapped
Next Topic:What is exactly Jubula license ?
Current Time: Tue Aug 11 20:05:59 GMT 2020
Powered by FUDForum. Page generated in 0.02126 seconds
