Home » Eclipse Projects » EGit / JGit » JGit seems to hang under Java 11 during a pull
JGit seems to hang under Java 11 during a pull [message #1804364] Sun, 24 March 2019 17:29 Go to next message
Michael Bell is currently offline Michael BellFriend
Evidence still being gathered, suggestions gratefully received.
Versions: 5.1.3.201810200350-r, 5.2.1.201812262042-r
Scenario: 6 different deploys in java 11 containers (mesos)
We have used jgit for years for a library that we use to poll github for chhanges to repos successfully.
In this program every minute we re pull and check for changes, and pass affected files list and shas up to the caller. This is done in a single threaded scheduled executor.
We are finding that after several days. the synchronization stops. Neither the scheduled thread nor jgit-workqueue look "suspicious"
"JGit-WorkQueue" - Thread t@67
java.lang.Thread.State: WAITING
at jdk.internal.misc.Unsafe.park(Native Method)
- parking to wait for <5e502c44> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
at java.util.concurrent.locks.LockSupport.park(LockSupport.java:194)
at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(AbstractQueuedSynchronizer.java:2081)
at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1170)
at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:899)
at java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1054)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1114)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.lang.Thread.run(Thread.java:834)
Locked ownable synchronizers:
- None
config-update-0" - Thread t@87
- parking to wait for <79fc6f28> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
- None
However, heavy debugging shows we go into this code and never "return"
LOG.trace("Configuration of credentials completed, setting remote {}", remoteIndex);
pull.setRemote("remote" + remoteIndex);
PullResult result = pull.call();
LOG.trace("Got result {}", result);
(The first log shows, but not the second)
We've tried turning off TLS 1.3 (openjdk has known issues) with -Djdk.tls.client.protocols=TLSv1,TLSv1.1,TLSv1.2
(It doesn't appear to have an effect however)
Re: JGit seems to hang under Java 11 during a pull [message #1805114 is a reply to message #1804364] Sun, 07 April 2019 18:07 Go to previous message
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=545936 for details, and workaround. Avoid jgit on Java 11 until its fixed, or use workaround.
Previous Topic:rebase interactive removes projects from workspace
Next Topic:Rename merge does not work - is there any workaround?
Current Time: Sat Apr 04 19:28:42 GMT 2020
Powered by FUDForum. Page generated in 0.02131 seconds
