Home » Eclipse Projects » EclipseLink » ReadOnly object query causes NPE in hashCode
ReadOnly object query causes NPE in hashCode [message #1804213] Wed, 20 March 2019 10:38 Go to next message
Stacktrace attached. (names modified because we can't share details)
Versions:
WebLogic Server 12.2.1.2.0
Eclipselink: 2.7.1
We're using WebLogic RMI.
We have a 1:N ClassA -> ClassA1. ClassA1 is @ReadOnly.
Not sure if the 1:N is even relevant, but good to know.
When we query for A1(s) we get a NPE in the hashCode method accessing the ID of the instance of A1.
Is there an issue with (lazy) loading ReadOnly objects if we have a custom hashCode method accessing the ID. Will the id be populated inside the hashCode?
Note when we remove the @ReadOnly there's no issue, and when we delete the hashCode and equals there's no issue.
Joel Lucuik
Re: ReadOnly object query causes NPE in hashCode [message #1804273 is a reply to message #1804213] Thu, 21 March 2019 12:46 Go to previous messageGo to next message
Hi Joel
Looks like the issue is with RMI serializing the collection which might not be fully fetched.
Can you show your A1 class and what exactly is getting the NPE in the hashcode method? how was the initial ClassA instance fetched from the database?
When you remove the hashcode/equality method implementations, are there any problems accessing the values in the collection on the other side?
Best Regards,
Chris
Re: ReadOnly object query causes NPE in hashCode [message #1804345 is a reply to message #1804273] Fri, 22 March 2019 13:49 Go to previous message
OK. Thanks
This gets a bit confusing. Take a look below. I don't know how this could happen. Line 175 is indicated.
public int hashCode() {
int result = (int) (id ^ (id >>> 32));
result = 31 * result + (nameKey != null ? nameKey.hashCode() : 0);
result = 31 * result + (subtitleKey != null ? subtitleKey.hashCode() : 0);
// result = 31 * result + (displayed ? 1 : 0);
// result = 31 * result + (readOnly ? 1 : 0);
result = 31 * result + (fieldPartialMsgKey != null ? fieldPartialMsgKey.hashCode() : 0);
>> result = 31 * result + (fieldOrder != null ? fieldOrder.hashCode() : 0);
result = 31 * result + (allMandatory ? 1 : 0);
return result;
I don't think the code can get a NPE regardless. Something doesn't make sense.
result: would have hit NPE earlier
id: MAYBE, but the line number is inconsistent
fieldOrder: is already checked
I will try and reproduce this, but any thoughts on any issues in the above method please let me know.
Its a query at the beginning of the stack
public List<A1> findA1s(A a) {
String query = "select t from A1 t where t.a.aPk = :aPk";
return entityManager
.createQuery(query, A1.class)
.setParameter("aPk", a.getAPk())
.getResultList();
Not that I'm aware of. But they want both left in and need ReadOnly.
The co-worker that created this bug was just starting on the project when he raised this, so we're just looking for "things not right" with @ReadOnly.
Let me know if you see anything obvious. I will try and reproduce this anyway.
Joel
Previous Topic:Moxy Java11
Next Topic:Eclipse Auto Save before build?
Current Time: Sat May 24 16:28:13 EDT 2025
Powered by FUDForum. Page generated in 0.03533 seconds
