Hi:
I'm trying to parse a CDA document using the mdht api, and in the example below I have a Problem coded as a snomed code with additional translation codes. The text is available in the narrative block. There is a reference value via Original Text. Is there a way to access the text using the content id in the originalText?
Narrative Block
<tr>
<td>
<content ID="_771588d9-7137-437d-9ac0-e8b0cfa3a8e4">Numbness</content>
<content styleCode="xSecondary">(782.0) (R20.0)</content>
<br/>
</td>
<td/>
<td/>
</tr>
Value in the Problem Observation block
<value xsi:type="CD" code="44077006" codeSystem="2.16.840.1.113883.6.96">
<originalText>
<reference value="#_771588d9-7137-437d-9ac0-e8b0cfa3a8e4"/>
</originalText>
<translation code="782.0" codeSystem="2.16.840.1.113883.6.103"/>
<translation code="R20.0" codeSystem="2.16.840.1.113883.6.90"/>
<translation code="27678" codeSystem="2.16.840.1.113883.3.247.1.1"/>
</value>
Usually when we populate CDA documents we also include the displayName along with the code, codeSystem and codeSystemName. The cda we are trying to integrate into our system originated from an external system.
[Updated on: Wed, 13 March 2019 01:59]
Report message to a moderator
