Re: Papyrus Oxygen new local palette unavailable [message #1804610 is a reply to message #1804458] |
Fri, 29 March 2019 13:18 |
the first step is to assure that you have semantic element type definitions for your stereotypes. You can generate these from the profile with tooling from Papyrus ToolSmith. Open your profile, then choose "generate tooling model" -> "element types."
There is documentation for a similar task here.
You should then make sure that these element types are registered in a plugin as shown below. Make sure that you have the source of the patched plugin in your workspace. Then you can start a 2nd eclipse instance and invoke the migration tool on a palette xml file. It will create a palette definition file as well as required graphical element type definitions.
You need to reference your palette definition from an architecture definition file - see also This thread
<extension
point="org.eclipse.papyrus.infra.types.core.elementTypeSetConfiguration">
<elementTypeSet
clientContextID="<context id, as referenced from a .architecture file>"
path="<path to the generated element types files">
</elementTypeSet>
</extension>
FUDForum. Page generated in 0.03456 seconds
