Home » Eclipse Projects » EGit / JGit » Is it possible to ignore 'message of the day' in egit via SSH
Is it possible to ignore 'message of the day' in egit via SSH [message #1803727] Thu, 07 March 2019 17:29 Go to next message
David Gonzalo is currently offline David GonzaloFriend
I'm having an issue with git operations via SSH from a server which has some sort of 'message of the day' upon SSH login.
This shows as a popup on my eclipse, blocking operations until I click on OK.
https://i.imgur.com/wINGlIK.png
Is there any way to prevent this and/or automatically dismiss this message?
Thanks and greetings!
Re: Is it possible to ignore 'message of the day' in egit via SSH [message #1803732 is a reply to message #1803727] Thu, 07 March 2019 19:16 Go to previous messageGo to next message
Thomas Wolf is currently offline Thomas WolfFriend
You could try installing EGit 5.2 or newer and switching in Preferences->Team->Git the SSH client from JSch to Apache MINA sshd. If this is a normal SSH "banner" message, it should be silently skipped because we didn't implement the UI part for it.
Re: Is it possible to ignore 'message of the day' in egit via SSH [message #1803758 is a reply to message #1803732] Fri, 08 March 2019 12:58 Go to previous message
Thanks! I'll give it a try and report back!
Previous Topic:Keybase.io repositories
Next Topic:Deadlock while "Auto Share GIT projects"
Current Time: Wed May 18 07:20:31 GMT 2022
Powered by FUDForum. Page generated in 0.01602 seconds
