Re: How to change the font type and size in 4DIAC editors? [message #1803505 is a reply to message #1803484] |
Fri, 01 March 2019 18:44   |
AFAIK we don't use hard coded fonts in 4diac. Therefore it should be possible to adjust all fonts used via the Help->Preferences dialog. There are two places to look. The first is General -> Appearance -> Colors and Fonts the second one is StructuredText -> Syntax Coloring There you can adjust the font for the Structured Text editor. I hope this helps
Re: How to change the font type and size in 4DIAC editors? [message #1803629 is a reply to message #1803607] |
Tue, 05 March 2019 17:52   |
Jep that is definitely a problem. I think the reason is not on the fonts but in another place. IEC 61499-2 clearly defines the coordinate system and sizes relative to the font sizes. We took a shortcut here. Making the diagram font setable would be a first step towards correctly drawing the diagrams on different screens and resolutions.
FUDForum. Page generated in 0.03139 seconds
