Home » Modeling » EMF » Change behavior without modifying generated code
Change behavior without modifying generated code [message #1803311] Tue, 26 February 2019 16:02 Go to next message
Wilbert Alberts is currently offline Wilbert AlbertsFriend
I would like to modify the behavior of the label provider without changing the generated code.
(The general idea is deescribed here: https://nirmalsasidharan.wordpress.com/2011/05/18/extending-emf-itemproviders-using-google-guice-i/ but then without the guice.)
I thought I could do that by extending the corresponding generated ItemProviders. For my ItemProviders to be used, I also had to extend the generated ItemProviderAdapterFactory. In order for that one to be used I had to modify the plugin.xml of the edit plugin. It registers the generated AdapterFactory and I changed that into MyAdapterFactory.
However, the emf generator generates a new extension each time I changed it into my AdapterFactory.
Is there a way to suppress generation of the extension in the plugin.xml by the emf generator? Or is there a better way to modify the behavior of the label providers without changing any generated code?
Greetings,
Wilbert.
Re: Change behavior without modifying generated code [message #1803330 is a reply to message #1803311] Wed, 27 February 2019 01:17 Go to previous messageGo to next message
Have you tried changing the marker in the plugin.xml? Also, if you disable Update Classpath in the GenModel, you can maintain the file manually.
Re: Change behavior without modifying generated code [message #1803342 is a reply to message #1803330] Wed, 27 February 2019 07:42 Go to previous messageGo to next message
Hi Ed,
Plugin.xml indeed contains a line like:
      <!-- @generated Ddf -->
Changing that into <!-- @generated Ddf NOT--> results in adding an additional extension. (So then I have two itemProviderAdapterFactories extensions.) As far as I could tell, I could not force the generated editor to prefer mine over the default generated one.
Assuming that the 'update classpath' option is found below 'Templates & Merge' I could not determine any change in behavior. In other words, the plugin .xml gets overwritten regardless whether it is true or false.
Did I trigger some bugs here for which I should file a bug report? FYI, I have been using the windows version of eclipse:
Eclipse Modeling Tools
Version: Photon Release (4.8.0)
Build id: 20180619-1200
with:
EMF Code Generation
Version: 2.13.0.v20180319-0813
Build: 201805310718
Greetings,
Wilbert
Re: Change behavior without modifying generated code [message #1803365 is a reply to message #1803342] Wed, 27 February 2019 12:16 Go to previous messageGo to next message
I haven't tried it (I'm on vacation) but I believe if you comment out the default generated registration in the plugin.xml (deleting the @generated marker because <!-- --> can't nest), it will not generate an additional one and you can then register a different one.
Re: Change behavior without modifying generated code [message #1803383 is a reply to message #1803365] Wed, 27 February 2019 15:50 Go to previous message
Hi Ed,
Brilliant!
That works. Thanks and enjoy your vacation!
Greetings,
Wilbert.
Previous Topic:Reference Model A classes in Model B without regenerating Model A
Next Topic:[CDO]
Current Time: Tue Feb 18 07:56:12 GMT 2020
Powered by FUDForum. Page generated in 0.07045 seconds
