Home » Modeling » TMF (Xtext) » [Formatter2] append newLine + spaces
[Formatter2] append newLine + spaces [message #1803049] Thu, 21 February 2019 13:20 Go to next message
ayman salah is currently offline ayman salahFriend
Hi all,
I am trying to achieve alignment with list opening bracket, but I can't.
Here is how I am trying:
Grammar:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
DSL returns XTDSL:
	models+=Model*
Model returns XTModel:
	{XTModel} 'startList' '(' greetings+=Greeting*')'';';
Greeting returns XTGreeting:
	'list' ids_list=identifier_list ':' 'endlist' ';';
identifier_list returns XTIdentifierList:
	ids+=identifier (',' ids+=identifier)*
identifier returns XTIdentifier:
	{XTIdentifier} ID
Formatter:
	def dispatch void format(XTDSL xtdsl, extension IFormattableDocument document) {
		xtdsl.models.forEach[format]
	def dispatch void format(XTModel xtmodel, extension IFormattableDocument document) {
		xtmodel.greetings.forEach[format; append[newLine]]
		xtmodel.regionFor.keyword("startList").append[oneSpace]
		xtmodel.regionFor.keyword("(").append[newLine]
		xtmodel.regionFor.keyword(")").prepend[noSpace]
		xtmodel.regionFor.keyword(";").prepend[noSpace]
		xtmodel.append[newLine]
		alignGreetingsOnOpenBracket(xtmodel.greetings, document)
	def void alignGreetingsOnOpenBracket(EList<XTGreeting> greetings, extension IFormattableDocument document) {
		val precedingString = "startList ("
		for (greeting : greetings) {
			greeting.prepend[space = Strings.repeat(" ", precedingString .length); highPriority]
What happens is:
startList (
list A : endlist;
list B : endlist;
list C : endlist;
While I expect:
startList (
           list A : endlist;
           list B : endlist;
           list C : endlist;
Why does append[newLine] result in ignoring any spaces added after (newLine = newLine and spaces ignored)?
I know that I can use interior[indent], but that would result in indenting using whatever tab width is set, which is not necessarily going to match the width of "startList (".
[Updated on: Sun, 24 February 2019 10:39]
Report message to a moderator
Re: [Formatter2] append newLine + spaces [message #1803055 is a reply to message #1803049] Thu, 21 February 2019 14:07 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Please use the indent feature to implement
Indentations
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: [Formatter2] append newLine + spaces [message #1803161 is a reply to message #1803055] Sun, 24 February 2019 10:37 Go to previous messageGo to next message
I know that I am supposed to use the indent feature.
But the indent feature uses the tab width set by the user.
I want to be able to set the indent width for each type of list to match the (list type + space + open bracket) width.
For example:
greetingsList (
               greeting g1;
               greeting g2;
asdList (
         asd a1;
         asd a2;
You get me?
[Updated on: Sun, 24 February 2019 10:38]
Re: [Formatter2] append newLine + spaces [message #1803162 is a reply to message #1803161] Sun, 24 February 2019 10:44 Go to previous messageGo to next message
did you have a look at the example here:
https://de.slideshare.net/meysholdt/xtexts-new-formatter-api
(Page 139)
[Updated on: Sun, 24 February 2019 11:08]
Re: [Formatter2] append newLine + spaces [message #1803165 is a reply to message #1803162] Sun, 24 February 2019 13:45 Go to previous messageGo to next message
Well, yes I have.
But that's not what I am talking about I guess.
If I understand correctly, the slide you are talking about adjusts the space width before the '=>' not before each transition (which is what I need).
The slide controls this part (*):
state baz
     1***=> foo;
     12**=> foo;
     123*=> foo;
end
I want to control this part (*):
state baz
*****1   => foo;
*****12  => foo;
*****123 => foo;
end
Let's say my grammar has states and has lists containing transitions. I would like to have the following result:
state baz
*****1   => foo;
*****12  => foo;
*****123 => foo;
end
list bar
****1   => foo;
****12  => foo;
****123 => foo;
end
Am I clear?
Re: [Formatter2] append newLine + spaces [message #1803170 is a reply to message #1803165] Sun, 24 February 2019 15:45 Go to previous messageGo to next message
this looks like a bug to me.
workaround:
def dispatch void format(XTModel xTModel, extension IFormattableDocument document) {
for (xTGreeting : xTModel.greetings) {
xTGreeting.regionFor.keyword("list").prepend[space = "\n "]
alternative solution:
https://stackoverflow.com/questions/45305293/how-to-define-different-indentation-levels-in-the-same-document-with-xtext-forma
can you please create a ticket at github.com/eclipse/xtext-core
Re: [Formatter2] append newLine + spaces [message #1805252 is a reply to message #1803170] Wed, 10 April 2019 12:23 Go to previous messageGo to next message
Done here https://github.com/eclipse/xtext-core/issues/1069.
Re: [Formatter2] append newLine + spaces [message #1837196 is a reply to message #1803049] Sun, 24 January 2021 14:29 Go to previous message
Olaf Bigalk is currently offline Olaf BigalkFriend
Instead adding spaces after the newline you can add spaces before the list keyword of the lines supposed to be indented.
Previous Topic:Using FQN rule in reference rules does not work as expexcted.
Next Topic:Strange Error Message - no clue what is wrong
Current Time: Wed Apr 21 15:31:24 GMT 2021
Powered by FUDForum. Page generated in 0.02142 seconds
