Home » Modeling » TMF (Xtext) » How to get the list of classes for scope
How to get the list of classes for scope [message #1803009] Wed, 20 February 2019 17:37 Go to next message
kozhaev Vladimir is currently offline kozhaev VladimirFriend
Hi all, I have the grammar(see it below) and there is the following rule.
DotValue:
	varRef=VariableDeclarationRef '.' (dotPart=DotValue?);
VariableDeclaration:
	name=ValuableID ((COLON type=TypeReference)?)
VariableDeclarationRef:
	decl=[VariableDeclaration|ValuableID];
As you can see, sometimes we don't specify the type of variable and get it from context. So the question is: in what way I can to get the ClassDefinition instance by className what I have in the variable?
Vladimir
grammar org.blockchain.rell.Rell with org.eclipse.xtext.common.Terminals
generate rell "http://www.blockchain.org/rell/Rell"
Model:
	entities+=(ClassDefinition)*
	operations+=(Operation)*;
ClassDefinition:
	'class' name=ID ('extends' superType=[ClassDefinition])? '{'
	attributeListField+=AttributeListField*
AttributeListField:
	mutable=Mutable? key=Key? index=Index? attributeList+=RelAttrubutesList ';';
Operation:
	"operation" name=ID "(" parameters=RelAttrubutesList? ")" "{" statements+=Statement* "}";
Statement:
	(relation=Relational | variable=OperationVariable | varInitiation=VarInitiation) ';';
VarInitiation:
	VariableDeclarationRef ('=' expression=Expression)?;
OperationVariable:
	assessModificator=(Var | Val) variable=Variable;
Variable:
	name=VariableDeclaration (('=' expression=Expression)?);
Relational:
	Create;
Create:
	'create' (entity=[ClassDefinition]) '(' (createWhatPart+=CreateWhatPart (','
	createWhatPart+=CreateWhatPart)*)? ')';
CreateWhatPart:
	(varDeclRef=[VariableDeclaration|ValuableID] '=')?
	condition+=Expression;
TupleValue:
	'(' members+=TupleValueMember (',' tuplePart+=TupleValueMember)* ')';
TupleValueMember:
	(name=ValuableID '=')? value=Expression;
ClassMemberDefinition:
	(classRef=ClassRef)? "." variableDeclarationRef=VariableDeclarationRef;
ClassRef:
	value=[TableNameWithAlias];
TableNameWithAlias:
	{ClassRefDecl} (name=ID COLON classDef=[ClassDefinition]) |
	{JustNameDecl} name=[ClassDefinition];
Expression:
	or=Or;
Or returns Expression:
	And ({Or.left=current} "or" right=And)*;
And returns Expression:
	Equality ({And.left=current} "and" right=Equality)*;
Equality returns Expression:
	Comparison ({Equality.left=current} op=(EQUALS | NOT_EQUALS | EQUALSS | NOT_EQUALSS)
	right=Comparison)*;
Comparison returns Expression:
	PlusOrMinus ({Comparison.left=current} op=(MORE_EQUAL | LESS_EQUAL | MORE | LESS)
	right=PlusOrMinus)*;
PlusOrMinus returns Expression:
	MulOrDiv (({Plus.left=current} PlusChar | {Minus.left=current} MinusChar)
	right=MulOrDiv)*;
MulOrDiv returns Expression:
	Primary ({MulOrDiv.left=current} op=(MulChar | DivChar)
	right=Primary)*;
Primary returns Expression:
	'(' Expression ')' |
	{Not} "not" expression=Primary |
	Atomic;
Atomic returns Expression:
	{IntConstant} value=IntWithMinus |
	{StringConstant} value=STRING |
	{ByteArrayConstant} value=BYTE_ARRAY_VALUE |
	{BoolConstant} value=('true' | 'false') |
	{MemberDefinition} value=ClassMemberDefinition |
	{CreateAtom} value=Create
	| {TupleRes} value=TupleValue
	| {DotValue} value=DotValue
	| {VariableRef} value=VariableDeclarationRef;
DotValue:
RelAttrubutesList:
	value+=Variable (',' value+=Variable)*;
	name=ValuableID ((COLON type=TypeReference)?);
TupleVarDeclaration:
	(name=ValuableID COLON)? type=TypeReference;
TypeReference:
	primitive=PrimitiveType | entityType=ClassType | tuple=TupleType | list=ListType | set=SetType | map=MapType;
ListType:
	List ListSpecification;
SetType:
	Set ListSpecification;
MapType:
	Map MapSpecification;
ListSpecification:
	LESS listType=TypeReference (QuestionChar?) MORE;
MapSpecification:
	LESS keySpec=TypeReference (QuestionChar?) ',' valSpec=TypeReference (QuestionChar?) MORE;
TupleType:
	'(' varDecl+=TupleVarDeclaration (',' varDecl+=TupleVarDeclaration)* ')';
ClassType:
	type=[ClassDefinition];
PrimitiveType:
	Text | Tuid | Pubkey | Name | Timestamp | Integer | Json | ByteArray | Boolean;
ValuableID:
	PrimitiveType | ID;
AmpersandModificator:
	PlusChar | MulChar | QuestionChar;
IntWithMinus:
	MinusChar? INT;
Name:
	'name';
Pubkey:
	'pubkey';
Timestamp:
	'timestamp';
Tuid:
	'tuid';
Boolean:
	'boolean';
Json:
	'json';
Integer:
	'integer';
Text:
	'text';
ByteArray:
	'byte_array';
List:
	'list';
Map:
	'map';
Set:
	'set';
Key:
	'key';
Index:
	'index';
Mutable:
	'mutable';
Var:
	'var';
Val:
	'val';
Ampersand:
QuestionChar:
PlusChar:
MinusChar:
MulChar:
DivChar:
terminal EQUALS:
terminal EQUALSS:
terminal NOT_EQUALS:
terminal NOT_EQUALSS:
terminal MORE_EQUAL:
terminal LESS_EQUAL:
terminal MORE:
terminal LESS:
terminal COLON:
terminal NULL:
	'null';
terminal BYTE_ARRAY_CHAR:
	'0' | '1' | '2' | '3' | '4' | '5' | '6' | '7' | '8' | '9' | 'a' | 'b' | 'c' | 'd' | 'e' | 'f' | 'A' | 'B' | 'C' | 'D'
	| 'E' | 'F';
terminal BYTE_ARRAY_PAIR:
	BYTE_ARRAY_CHAR BYTE_ARRAY_CHAR;
terminal BYTE_ARRAY_VALUE:
	'x' (('\'' BYTE_ARRAY_PAIR* '\'') | ('"' BYTE_ARRAY_PAIR* '"'));
Re: How to get the list of classes for scope [message #1803101 is a reply to message #1803009] Fri, 22 February 2019 12:25 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
could you please rephrase the question? What problem do you want to solve? Could you please provide a few lines of sample code with comments such that it becomes easier to follow. Unfortunately I don't have the time to understand the entire grammar and make some sense of it.
Thank you
Sebastian
Re: How to get the list of classes for scope [message #1803118 is a reply to message #1803101] Fri, 22 February 2019 16:47 Go to previous messageGo to next message
Well, I want to get the reference on the ClassDefinition by its name. In what I can to do it?
[Updated on: Fri, 22 February 2019 16:55]
Report message to a moderator
Re: How to get the list of classes for scope [message #1803126 is a reply to message #1803118] Fri, 22 February 2019 19:40 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Please explain what you want to achieve. E.g. using sample models and pseudo code for scoping
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: How to get the list of classes for scope [message #1803142 is a reply to message #1803126] Sat, 23 February 2019 11:55 Go to previous messageGo to next message
I want to create the method something like following
getEObject(String name, RuleName ruleName) what will return list of EObject with given name and the rule.
Re: How to get the list of classes for scope [message #1803143 is a reply to message #1803142] Sat, 23 February 2019 12:11 Go to previous messageGo to next message
But why. What is the problem you want to solve
[Updated on: Sat, 23 February 2019 12:30]
Re: How to get the list of classes for scope [message #1803152 is a reply to message #1803143] Sat, 23 February 2019 17:51 Go to previous messageGo to next message
Well, as I told, I want to create the scope for the expression like <classReference> . <field> and as you can see, in the my grammar, I have default type. I.e. if the field name is the same with the type name I can skip the type.
Re: How to get the list of classes for scope [message #1803177 is a reply to message #1803152] Sun, 24 February 2019 19:49 Go to previous messageGo to next message
This is the fragment of the my ScopeProvider
case (container instanceof DotValue): {
				val DotValue dotValue = container as DotValue;
				if (dotValue.eContainer instanceof DotValue) {
					val parentDotValue= dotValue.eContainer as DotValue;
					val parentValue=parentDotValue.decl;
					switch(parentValue){
						case (parentValue instanceof ClassMemberDefinition):{
							val classMemberDefinition=parentValue as ClassMemberDefinition;
							if (classMemberDefinition.variableDeclarationRef!==null){
								val parentClassMemberDef=classMemberDefinition.variableDeclarationRef;
								val typeFor=parentClassMemberDef.typeFor
								if (typeFor instanceof RellClassType){
									val variableDeclarationList=(typeFor as RellClassType).rellClassDefinition.attributeListField.makeVariableDeclarationList
									return Scopes::scopeFor(variableDeclarationList)
					return variableDeclarationRefScope(variableDeclarationRef,
						dotValue.eContainer.notExressionContainer, ref);
				} else {
					return super.getScope(variableDeclarationRef, ref)
def typeFor(VariableDeclarationRef variableDeclarationRef){
		if (variableDeclarationRef.name instanceof VariableDeclaration){
			val variableDeclaration=variableDeclarationRef.name as VariableDeclaration;
			val TypeReference typeReference=variableDeclaration.type
			if (typeReference!==null){
				return typeReference.typeForTypeRef
			return null
In the other hand see my variable declaration ref rule
	name=[VariableDeclaration|ValuableID];
	name=ValuableID ((DOUBLE_QUOTE type=TypeReference)?);
Sometimes I don't specify the variable type - just get it by the name(variable name is the same with the type name)
So, I want to get the EOblect by name and type of it. In what way I can to do it?
Vladimir
Re: How to get the list of classes for scope [message #1803178 is a reply to message #1803177] Sun, 24 February 2019 20:04 Go to previous messageGo to next message
option 1: avoid problem by using IDerivedStateComputer and SyntheticLinkingSupport to create the reference by naming convention if not there
https://www.eclipse.org/forums/index.php/m/1769803
option 2: using a filtering scope for your field references and filter by prefix
option 3: search the xtext index similar to here https://www.eclipse.org/forums/index.php/m/754503/?srch=xtext+getVisibleContainers#msg_754503 (+ local manual search)
Re: How to get the list of classes for scope [message #1803212 is a reply to message #1803178] Mon, 25 February 2019 11:24 Go to previous messageGo to next message
May I ask to tell me something more about the second option?
Re: How to get the list of classes for scope [message #1803213 is a reply to message #1803212] Mon, 25 February 2019 11:31 Go to previous messageGo to next message
in the scope provider you can stick delegateGetScope(the default impl) into a new FilteringScope.
the filtering scope then lets you filter the stuff.
=> instead of collection the fields manually you allow all and filter them by name.
am not sure if this works in your usecase
Re: How to get the list of classes for scope [message #1803215 is a reply to message #1803213] Mon, 25 February 2019 11:44 Go to previous messageGo to next message
You might play w ith the import scope class as well
Re: How to get the list of classes for scope [message #1803234 is a reply to message #1803215] Mon, 25 February 2019 13:51 Go to previous messageGo to next message
Is it a good idea to move back by the EObject.eContainer until reach the root. Then go down to see what classes I have with this name? Then get the scope by fields of the class?
Re: How to get the list of classes for scope [message #1803235 is a reply to message #1803234] Mon, 25 February 2019 14:04 Go to previous message
It depends
It won't work with multiple files
For local ones for sure
Previous Topic:DSL Generate Documentation
Next Topic:Error saving an EMF model with Crossreferences in a new XtextResource
Current Time: Thu Sep 24 11:51:55 GMT 2020
Powered by FUDForum. Page generated in 0.03009 seconds
