Home » Eclipse Projects » Remote Application Platform (RAP) » Using XWorker to develop SWT & RAP Programs
Using XWorker to develop SWT & RAP Programs [message #1802873] Mon, 18 February 2019 11:57 Go to next message
zhangyuxiang Mising name is currently offline zhangyuxiang Mising nameFriend
This post will briefly introduce how to use XWorker to develop SWT and RAP applications. I hope you can use and join XWorker. XWorker is an open source software under Apache 2.0 license.
XWorker is the development platform of dynamic model. Dynamic model is a model-based object-oriented programming method. For XWorker and dynamic model, you can refer to the home page of XWorker https://www.xworker.org.At present, XWorker is still under development. I hope to receive your suggestions.
Online Examples https://www.xworker.org/rap?app=rwt.RwtExample.
One minute GIF presentation creates, edits, publishes and runs SWT models .
https://www.xworker.org/files/2019/0218/165257swt.gif
The 34 seconds GIF demo creates, edits, and packages RAP applications.
https:///www.xworker.org/files/2019/0218/172157rwt.gif
Re: Using XWorker to develop SWT & RAP Programs [message #1802874 is a reply to message #1802873] Mon, 18 February 2019 11:58 Go to previous messageGo to next message
Brief Introduction of Dynamic Model
Dynamic model is a model-based object-oriented programming method, in which objects, classes and behaviors are represented by models, while models are tree-structured data and can be represented by XML.
Dynamic models are executed by interpretation, while models are data that can be modified at any time, so dynamic models can be used to program dynamically while the system is running.
The dynamic model engine used by XWorker is implemented in Java, which relies on Java to run.
The dynamic model itself is relatively simple, but powerful programs can be developed.
Re: Using XWorker to develop SWT & RAP Programs [message #1802875 is a reply to message #1802874] Mon, 18 February 2019 11:58 Go to previous messageGo to next message
A Brief Introduction to XWorker's SWT Subproject
The swt used here is a subproject of xworker. XWorker chose SWT as its interface, so we modeled SWT, through which we can quickly develop SWT and RAP applications.
XWorker has modeled most of the SWT and Nebula controls, and integrated third-party controls such as TkuiCss, Jfreechart and Barcode. XWorker has also written a large number of composite controls and frameworks.
The SWT model in XWorker still has a lot of work to develop. I hope that one day Eclipse will be able to use dynamic models to make SWT-related models by itself. After all, we are only users of SWT, not professional.
Re: Using XWorker to develop SWT & RAP Programs [message #1802876 is a reply to message #1802875] Mon, 18 February 2019 12:03 Go to previous messageGo to next message
Models can be integrated into Java
See https://www.xworker.org/do?sc=xworker.app.orgweb.web.Index&id=1692
https://www.xworker.org/files/2019/0218/200223modeljava.png
Re: Using XWorker to develop SWT & RAP Programs [message #1803034 is a reply to message #1802876] Thu, 21 February 2019 09:52 Go to previous messageGo to next message
Features
My final goal is to donate XWorker's SWT-related sub-projects to Eclipse, or Eclipse to rewrite the relevant models, hoping to get anyone's help to achieve this wish.
The following link is a 2:27 second video, showing some features of the SWT model, hoping you can learn more about the SWT model.
https://www.xworker.org/files/2019/0221/173007features.mp4
Re: Using XWorker to develop SWT & RAP Programs [message #1803132 is a reply to message #1803034] Sat, 23 February 2019 05:04 Go to previous messageGo to next message
Why Choose Dynamic Model
This is because the dynamic model is simple, but it can be used to write powerful applications.
For example, it can be used to develop new programming methods. We know that if we can turn the programming process into a selection process, it is possible to add AI to automate programming. The next 51 seconds video demonstrates how to write a SWT interface by choice, based on the fact that the application can change its model at runtime.
It should be noted that the above functions are still an idea of XWorker.
https://www.xworker.org/files/2019/0223/123704swtselector.mp4
Re: Using XWorker to develop SWT & RAP Programs [message #1803133 is a reply to message #1803132] Sat, 23 February 2019 05:05 Go to previous message
Join and help us
XWorker is still in the stage of creating various models, among which SWT model is the first mature model that can be applied. In addition to SWT, there are WEB, AI and games.
The biggest challenge for XWorker is to let you understand the dynamic model. I haven't found a suitable method yet. I think the possible reasons are:
1. The dynamic model is so simple that it is difficult to figure out its use. The solution is to try to use it.
2. Dynamic models are similar to many technologies, and it's easy to feel that others have already done it. In fact, the foundation of dynamic model is meta-model, and the structure of meta-model is itself.
Honestly speaking, I have failed to introduce dynamic model once. At that time, I was mainly caught in the philosophy of metamodels. Fortunately, I have passed through this difficulty now. I hope this time will be successful. I hope you can join us and help us.
Previous Topic:Eclipse based on Maven workbench app
Next Topic:Password Text field, RAP 3.7, Firefox 65
Current Time: Sat Sep 26 05:49:58 GMT 2020
Powered by FUDForum. Page generated in 0.02244 seconds
