Home » Newcomers » Newcomers » How to upgrade Eclipse?
How to upgrade Eclipse? [message #1802778] Fri, 15 February 2019 14:56 Go to next message
Ewa Sliwinska is currently offline Ewa SliwinskaFriend
I'm trying to follow the steps from this tutorial in Eclipse 2018-09.
After pasting URL I can't clikc "OK" like it is described - I can feel also the name of the site and click "Add".
Then I'm supposed to go to "Help > Check for Updates".
But what I see is a list of available software from added site... and I don't know what to do ;)
Should I mark all of them? It doesn't look like Eclipse itself upgrade.
I know I can always install from scratch, but I wanted to upgrade this instance.
Thanks in advance.
Re: How to upgrade Eclipse? [message #1802915 is a reply to message #1802778] Mon, 18 February 2019 23:56 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Which version are you on now? What site URL are you adding?
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: How to upgrade Eclipse? [message #1802928 is a reply to message #1802915] Tue, 19 February 2019 08:34 Go to previous messageGo to next message
Nitin - I was on 2018-09 version, like I wrote. I was adding the http://download.eclipse.org/releases/2018-12/ update site from the example.
Re: How to upgrade Eclipse? [message #1802953 is a reply to message #1802778] Tue, 19 February 2019 15:15 Go to previous messageGo to next message
Just to make sure, did you accidentally hit the Install New Software menu item instead? Checking for updates should either throw up a progress dialog or show that it's checking your sites for updates in the Progress view, and when done open an installation dialog with the updates it found.
Nitin Dahyabhai
Re: How to upgrade Eclipse? [message #1802956 is a reply to message #1802953] Tue, 19 February 2019 15:51 Go to previous message
Yeah, I think so ;)
Thank you.
Previous Topic:Eclipse installation
Next Topic:Workbench could not be found in the registry
Current Time: Mon Jan 27 00:06:13 GMT 2020
Powered by FUDForum. Page generated in 0.03040 seconds
