Re: The version of the compiler could not be determined [message #1802658 is a reply to message #1802645] |
Wed, 13 February 2019 12:29 |
the format of your path is wrong. Just to help, my TITAN installation path is this:
C:\Users\ethxxx\git\titan.core\Install
Follow this format or push the button "Browse..." and find your titan root dir. The format of the path will be correct!
Hopefully this helps. Waiting Your answer and
Best regards
Jeno Balaskó
TITAN team, Ericsson
Re: The version of the compiler could not be determined [message #1802847 is a reply to message #1802787] |
Mon, 18 February 2019 08:01 |
Hi ,
there isn't any firewall related problem.
Could you check your titan command line, please?
1. Open a cygwin terminal and type:
You should receive something like this:
TTCN-3 and ASN.1 Compiler for the TTCN-3 Test Executor
Product number: CRL 113 200/6 R5B
Build date: Feb 15 2019 11:46:44
Compiled with: GCC 7.3.0
Using OpenSSL 1.0.2p 14 Aug 2018
Copyright (c) 2000-2018 Ericsson Telecom AB
License information:
License file : /cygdrive/c/Users/ethbaat/license_98.dat
Unique ID : 98
Licensee : Jen▒ Balask▒
E-mail : jeno.balasko@ericsson.com
Company : Ericsson Hungary
Department : ETH/
Valid from : Fri Sep 20 00:00:00 2002
Valid until : Fri Mar 29 23:59:59 2019
Limitation : USER
Host ID : 00000000
Login name : ethbaat
Versions : from 1.1.pl0 until 1.99.pl99
Languages : TTCN3 ASN1
Encoders : RAW TEXT BER PER XER
Applications : CODEGEN TPGEN SINGLE MCTR HC LOGFORMAT
Max PTCs : 10000
The license key is valid.
a)If you see this, your eclipse setting is the problem.
b)If you can't see this, your cygwin installation or your titan installation or your titan environment setting is the root cause if the problem. In this case I would suggest to read and check titan.core/README.cygwin again.
What do you see after executing the command ?
Waiting your answer
Jeno
Re: The version of the compiler could not be determined [message #1803087 is a reply to message #1803048] |
Fri, 22 February 2019 08:14 |
I should correct my information. Hopefully you have got a titan.core (in command line) and a titan.EclipsePlug-ins with version of open source. This open source versions are without license file and license file checking mechanism.
So the command compiler -v shall produce the same as I mentioned but without license info.
1.a Could you send us the copy of the output of
( in terminal) and
1.b the snapshot of Eclipse Window>Preferences>TITAN Preferences. (Send more snapshots if possible.)
2. Can you send me
2.a the version of your titan.EclipsePlug-ins (Eclipse Help>About Eclipse platform>Installation details>Plug-ins) and
2.b the source where you downoaded it from?
3. Can you inform about your time zone or city? We should find a common "time slot"when we can change information quicker, more effectively. 3 days/cycle is not effective.
4. What is the point where you cannot continue your work with titan and eclipse?
Waiting your answer
Jeno
FUDForum. Page generated in 0.03702 seconds
