Home » Language IDEs » Java Development Tools (JDT) » How to switch to the debug perspective from a new debugger launch?(I need the eclipse debug framework to switch to the debug perspective.)
How to switch to the debug perspective from a new debugger launch? [message #1802239] Mon, 04 February 2019 17:52 Go to next message
HI! I'm creating a debugger and I can not figure out a way to get the "perspective switch" message to show up. That is, lets say I am in the java perspective and run a 'java application' in debug mode. In this case, a dialog will pop up asking if I want to switch to the debug perspective. When a user launches the debugger I'm creating, how can I get that same dialog if I'm not in the debug perspective?
Re: How to switch to the debug perspective from a new debugger launch? [message #1802254 is a reply to message #1802239] Tue, 05 February 2019 06:25 Go to previous messageGo to next message
IIRC it happens automatically, or rather it happens as specified by the switch to debug perspective preference.
BUT only if the PerspectiveManager is running. I therefore call the following 'helper'.
* Load a DebugUI class to ensure the PerspectiveManager is ready to create a Perspective
public static void loadPerspectiveManager() {
DebugUITools.class.getName();
Ed Willink
Re: How to switch to the debug perspective from a new debugger launch? [message #1802272 is a reply to message #1802254] Tue, 05 February 2019 11:32 Go to previous message
HI! Thanks for the suggestion! It is *supposed* to switch automatically as I understand it. I even have this in my launchConfigurationTabGroup:
<launchMode
mode="debug"
perspective="org.eclipse.debug.ui.DebugPerspective"
description="some description.">
</launchMode>
I tried your suggestiong and it didn't help. I have to wonder if I'm not firing the correct debug event at suspend time which will tell the PerspectiveManager that it needs to prompt for a switch to the debug perspective.
Previous Topic:JUnit 5 Slowdown at 57%
Next Topic:Using a windowbuilder project
Current Time: Tue Jul 08 05:25:41 EDT 2025
Powered by FUDForum. Page generated in 0.31285 seconds
