Home » Eclipse Projects » e(fx)clipse » Is there an approximate release date for efxclipse 3.5?
Is there an approximate release date for efxclipse 3.5? [message #1802215] Mon, 04 February 2019 12:18 Go to next message
Thomas Fahrmeyer is currently offline Thomas FahrmeyerFriend
Member
I can't wait for the release of 3.5 because there are the renderer widget implementations public classes which can easily be extended. We have to create a extension of PartImpl for instance and put it into the same package in our code base to make it customizable. We want to avoid it.
Thanks for the good work
Thomas
Re: Is there an approximate release date for efxclipse 3.5? [message #1802226 is a reply to message #1802215] Mon, 04 February 2019 17:47 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
I'll let you know the exact date but from my point of view 3.5 is fairly done but I need to ask my coworkers if they need anything urgent in.
Re: Is there an approximate release date for efxclipse 3.5? [message #1802247 is a reply to message #1802226] Tue, 05 February 2019 07:51 Go to previous messageGo to next message
Member
Great :)
Is there any changelog? I'v only seen the public Widget implementation classes, what is very good.
Thanks.
Thomas
Re: Is there an approximate release date for efxclipse 3.5? [message #1802249 is a reply to message #1802247] Tue, 05 February 2019 08:15 Go to previous messageGo to next message
See the issues in efxclipse-rt assigned to the 3.5 milestone
Re: Is there an approximate release date for efxclipse 3.5? [message #1802400 is a reply to message #1802249] Fri, 08 February 2019 09:49 Go to previous message
The release date is Feb, 28th 2019
Previous Topic:What is the best way to remove a MToolControl from main toolbar if part is deactivated?
Next Topic:Which eclipse version will be bundled with efxclipse 3.5?
Current Time: Fri Oct 30 17:30:32 GMT 2020
Powered by FUDForum. Page generated in 0.01938 seconds
