Home » Eclipse Projects » Sirius » How to select all layers at once
How to select all layers at once [message #1802203] Mon, 04 February 2019 07:28 Go to next message
Prajna VGFriend
Member
In diagram I have 5-6 layers. We can see the required layers once we checked in tabbar. I want to add one more option in that layers list called Select all so that we can select all the layers at once. Can I do that by adding service / external java action. Or is there any extension for adding one layer for those list.
I added one layer with name 'Select all'. But for layer we can not add any service method and java action. Can anyone help me on this!!
[Updated on: Mon, 04 February 2019 07:28]
Report message to a moderator
Re: How to select all layers at once [message #1802216 is a reply to message #1802203] Mon, 04 February 2019 12:26 Go to previous messageGo to next message
Laurent Fasani is currently offline Laurent FasaniFriend
Hello
It looks like an enhancement. We could effectively imagine something like check butons in the drop down button list with a special Select all check button.
But for your case adding a fake layer just to have a new entry in the menu list does not seem a good idea.
You could instead add a "Popup Menu" under the "Tool Section" in the odesign in order to have a "Select All" action available in contextual menu in your diagram.
Then you can call a java service to activate all layers.
The pointers below will be helpful to get all layers and activate them
org.eclipse.sirius.diagram.business.internal.metamodel.helper.LayerHelper.getAllLayers(DiagramDescription)
org.eclipse.sirius.diagram.tools.api.command.ChangeLayerActivationCommand
regards
Laurent
Laurent Fasani - Obeo
Re: How to select all layers at once [message #1802242 is a reply to message #1802216] Tue, 05 February 2019 05:19 Go to previous message
Prajna VGFriend
Member
It works!! Thank you Laurent
With regards,
Prajna
Previous Topic:"diagram" variable is gone
Next Topic:Only one node creation and deletion detection
Current Time: Sun Jul 05 06:51:38 GMT 2020
Powered by FUDForum. Page generated in 0.02199 seconds
