Home » Eclipse Projects » Virgo » upgrade version of spring framework used in virgo
upgrade version of spring framework used in virgo [message #1802159] Sat, 02 February 2019 08:57 Go to next message
Martin Zukal is currently offline Martin ZukalFriend
we would like to upgrade version of spring framework to a higher version than the one shipped with virgo 3.7.2. I found this FAQ: https://wiki.eclipse.org/Virgo/FAQ#How_can_I_change_the_version_of_Spring_framework_in_the_user_region.3F which unfortunately describes the steps for virgo 3.6.4 and also states that the described approach does not work in virgo 3.7.2.
Virgo 3.7.2 is shipped with spring version 4.3.9 which will be supported until 2020 therefore we are investigating on options how we can upgrade spring version. I already checked that there are OSGi bundles of spring jars provided by servicemix so that is not the limiting factor.
Any hints or links how this can be done will be very much appreciated. I would also appreciate any comments to what should we look for before/during the upgrade if someone already tried that.
Best regards
Martin
Re: upgrade version of spring framework used in virgo [message #1804009 is a reply to message #1802159] Fri, 15 March 2019 15:08 Go to previous message
Joel Traber is currently offline Joel TraberFriend
Hi guys,
Is there any news to that topic?
Thanks, Joël
Previous Topic:Which Version Eclipse IDE for JSF2.2
Next Topic:An issue with upgrading taglibs-standard to 1.2.5 in virgo-tomcat-server-3.6.4.RELEASE.zip
Current Time: Sat Mar 28 19:24:22 GMT 2020
Powered by FUDForum. Page generated in 0.02925 seconds
