Home » Modeling » M2T (model-to-text transformation) » Error UML to Java Example(Error UML to Java Example)
Error UML to Java Example [message #1802157] Sat, 02 February 2019 08:08 Go to next message
Farooque Azam is currently offline Farooque AzamFriend
Environment: Eclipse 2018 12 (Modeling Tools) - Java 10 - Windows 10
After installing the example,
- While opening uml2java.mtl file in editor it shows numerous errors
- When I try to run it with provided 'model.uml' file with Runner=Java Application, it gives following Error in console: -
java.util.MissingResourceException: Can't find bundle for base name platform:/plugin/org.eclipse.acceleo.examples.uml2java/org/eclipse/acceleo/examples/uml2java/properties/default.properties, locale en_US
at java.base/java.util.ResourceBundle.throwMissingResourceException(Unknown Source)
at java.base/java.util.ResourceBundle.getBundleImpl(Unknown Source)
at java.base/java.util.ResourceBundle.getBundle(Unknown Source)
at org.eclipse.acceleo.engine.internal.environment.AcceleoPropertiesLookup.addProperties(AcceleoPropertiesLookup.java:93)
at org.eclipse.acceleo.engine.generation.AcceleoEngine.addProperties(AcceleoEngine.java:97)
at org.eclipse.acceleo.engine.service.AcceleoService.addPropertiesFile(AcceleoService.java:245)
at org.eclipse.acceleo.engine.service.properties.AbstractAcceleoPropertiesLoaderService.initializeService(AbstractAcceleoPropertiesLoaderService.java:54)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.generate(AbstractAcceleoGenerator.java:205)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.generate(AbstractAcceleoGenerator.java:172)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.doGenerate(AbstractAcceleoGenerator.java:159)
at org.eclipse.acceleo.examples.uml2java.main.Uml2java.doGenerate(Uml2java.java:205)
at org.eclipse.acceleo.examples.uml2java.main.Uml2java.main(Uml2java.java:163)
The generation failed to generate any file because there are no model elements that matches at least the type of the first parameter of one of your main templates.
The problem may be caused by a problem with the registration of your metamodel, please see the method named "registerPackages" in the Java launcher of your generator. It could also come from a missing [comment @main/]
in the template used as the entry point of the generation.
[Updated on: Sat, 02 February 2019 08:13]
Report message to a moderator
Re: Error UML to Java Example [message #1802160 is a reply to message #1802157] Sat, 02 February 2019 09:39 Go to previous message
Sorry this appears to be sub-issue b) from https://bugs.eclipse.org/bugs/show_bug.cgi?id=533585 which I reported on 2018-04-14 in good time for a fix in Photon (2018-06). There has been no Bugzilla comment or fix in 2018-09 or 2018-12.
Since 2018-04-14 there have been quite a few commits to keep releng ticking over and three files have fixes, but sadly nothing that contributes to documentation/examples.
Ed Willink
Previous Topic:Changes in metamodel is not recognized by Acceleo?
Next Topic:Is it possible to generate Java code from a resource only loaded in memory?
Current Time: Tue Aug 09 14:58:47 GMT 2022
Powered by FUDForum. Page generated in 0.02856 seconds
