Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Issues compiling Forte with OPC UA module included in Linux(Ubuntu 16.04)
Issues compiling Forte with OPC UA module included in Linux(Ubuntu 16.04) [message #1802094] Fri, 01 February 2019 04:04 Go to next message
Manas Das is currently offline Manas DasFriend
Dear All,
I am having issues while compiling OPC UA on linux (Ubuntu-16.04) after the command make -j.
PFA for the screenshot.
Do i have to build forte before running the below commands or the following command takes care of forte compilation for OPC UA.
Or Am i missing some steps.A hint will be great.
$ cd ~/4diac/forte/build
$ cmake -DCMAKE_BUILD_TYPE=Debug -DFORTE_ARCHITECTURE=Posix -DFORTE_MODULE_CONVERT=ON \ -DFORTE_COM_ETH=ON -DFORTE_MODULE_IEC61131=ON -DFORTE_COM_OPC_UA=ON \ -DFORTE_COM_OPC_UA_INCLUDE_DIR=$HOME/4diac/open62541/build \ -DFORTE_COM_OPC_UA_LIB_DIR=$HOME/4diac/open62541/build/bin \ -DFORTE_COM_OPC_UA_LIB=libopen62541.so \ -DFORTE_COM_OPC_UA_VERSION=master ..
Manas
Re: Issues compiling Forte with OPC UA module included in Linux(Ubuntu 16.04) [message #1802107 is a reply to message #1802094] Fri, 01 February 2019 09:33 Go to previous messageGo to next message
Alois Zoitl is currently offline Alois ZoitlFriend
unfortunately this is a Bug that slipped into the 1.10.1 release [1]. It is already fixed in the maintenance branch for the 1.10.x release train and will make it in the 1.10.2 release. In the meantime you can checkout the 4diac FORTE repository and take the latest version from the 1.10.x branch. Also we updated the OPC UA documentation to clearly state which open62541 version you should take.
Alois
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=543532
Re: Issues compiling Forte with OPC UA module included in Linux(Ubuntu 16.04) [message #1802158 is a reply to message #1802107] Sat, 02 February 2019 08:22 Go to previous messageGo to next message
Dear Sir,
Thanks for the information. I am able to compile it now.
Manas
[Updated on: Sat, 02 February 2019 09:51]
Report message to a moderator
Re: Issues compiling Forte with OPC UA module included in Linux(Ubuntu 16.04) [message #1802163 is a reply to message #1802158] Sat, 02 February 2019 09:55 Go to previous message
I always clone and get the branch I want with the following sequence:
git clone https://git.eclipse.org/r/4diac/org.eclipse.4diac.forte
git checkout 1.10.x
To be really sure I have the latest version I perform a git pull afterwards.
In order to reduce your effort we are also having the git information in the source zips of 4diac FORTE. So you could also perform a git checkout 1.10.x and a git pull there.
I hope this helps,
Alois
Previous Topic:Issues compiling Forte with OPC UA module included in Windows
Next Topic:Issues on implementing OPC UA with 4DIAC and OpenModelica
Current Time: Mon Jan 27 19:11:21 GMT 2020
Powered by FUDForum. Page generated in 0.04164 seconds
