Home » Newcomers » Newcomers » JRE Missing - Eclipse won't install with JDK 11(Eclipse installer does not work with JDK 11)
JRE Missing - Eclipse won't install with JDK 11 [message #1802066] Thu, 31 January 2019 15:48 Go to next message
Vincent Marfaing is currently offline Vincent MarfaingFriend
I tried to install Eclipse, it open this page: https://download.eclipse.org/oomph/jre/index-handler.php?vm=1_1_7_0_64_0&pn=Eclipse%20Installer&pu=http://wiki.eclipse.org/Eclipse_Installer&pi=http://download.eclipse.org/oomph/jre/128x128.png Telling me I do not have java installed and linking to different JDK's and JRE's Versions. I installed JDK11, the first link, but it still gives me the same error -> JRE Missing.
When I installed JDK8 witch contains JRE 8 (IIRC). I was able to install Eclipse.
1. Why is JDK 11 not enough to install Eclipse?
2. Why does the page, JRE missing, recommend JDK 11 as the top most option?
Thanks for any input here.
Re: JRE Missing - Eclipse won't install with JDK 11 [message #1802078 is a reply to message #1802066] Thu, 31 January 2019 21:16 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Is that a 64-bit Java 11?
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: JRE Missing - Eclipse won't install with JDK 11 [message #1802095 is a reply to message #1802078] Fri, 01 February 2019 04:13 Go to previous messageGo to next message
Did you really install Java 11, or just unzip it? (There are two downloads for it.) If you just unzipped it, did you put it on the system path? The installer looks in the system registry and on the system path. If it's not there, it won't find it automatically.
Re: JRE Missing - Eclipse won't install with JDK 11 [message #1802148 is a reply to message #1802095] Sat, 02 February 2019 00:47 Go to previous message
index.php/fa/34787/0/
This is how JDK is installed viewed in Windows Programm deinstaller.
Ok so you gave me the right hint. Somehow the PATH entries where mixed up. By disabling them I can now install Eclipse on JDK11. Thanks.
  • Attachment: jdk11.PNG
    (Size: 4.85KB, Downloaded 1941 times)
[Updated on: Sat, 02 February 2019 00:58]
Report message to a moderator
Previous Topic:Suggestions for the "Read This First" sticky
Next Topic:Can't connect to any repository... Session.connect: java.net.SocketException: Connection reset
Current Time: Sat Apr 04 16:35:05 GMT 2020
Powered by FUDForum. Page generated in 0.02956 seconds
