Unclonnable property - ElkReflect [message #1802038] |
Thu, 31 January 2019 03:21  |
Hi everybody,
When trying to layout or convert a graph to JSON format, I get the following error :
2019-01-31 10:02:53,032 [AWT-EventQueue-0] ERROR GENERAL - Unhandled exception - Couldn't clone property 'org.eclipse.elk.junctionPoints'. Make sure it's type is registered with the ElkReflect utility class.
java.lang.IllegalStateException: Couldn't clone property 'org.eclipse.elk.junctionPoints'. Make sure it's type is registered with the ElkReflect utility class.
at org.eclipse.elk.graph.properties.Property.getDefault(Property.java:140)
The error above happened when trying to convert the graph to a JSON. The same message occured, but with "org.eclipse.elk.nodeLabels.padding" instead of "org.eclipse.elk.junctionPoints", when trying to layout the graph with LayeredLayoutProvider.
This doesn't happen when I'm operating over a simple graph (5 nodes, 6 edges, some ports), but happens on a more complex graph (built by iterating over a SysML model).
How should I proceed so that "types are registered with the ElkReflect utility class", as the error message says ? Is it a dependency problem or does it have to something to do with the graph construction process ?
I'm only using basic ELK functions for constructing my graph (ElkGraphFactory.createElkNode, ElkGraphFactory.createSElkPort, ElkGraphUtil.createSimpleEdge).
Thanks in advance
Re: Unclonnable property - ElkReflect [message #1859269 is a reply to message #1802100] |
Thu, 25 May 2023 08:23  |
The context using ELK : I am using ELK Eclipse plugin
i am getting the follwing issue when i try to layout my diagram.
Caused by: org.eclipse.e4.core.di.InjectionException: java.lang.IllegalStateException: Couldn't clone property 'org.eclipse.elk.nodeLabels.padding'. Make sure its type is registered with the ElkReflect utility class.
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:68)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:319)
FUDForum. Page generated in 0.05861 seconds
