Home » Modeling » Eclipse Layout Kernel » Unclonnable property - ElkReflect
Unclonnable property - ElkReflect [message #1802038] Thu, 31 January 2019 03:21 Go to next message
Hi everybody,
When trying to layout or convert a graph to JSON format, I get the following error :
2019-01-31 10:02:53,032 [AWT-EventQueue-0] ERROR GENERAL - Unhandled exception - Couldn't clone property 'org.eclipse.elk.junctionPoints'. Make sure it's type is registered with the ElkReflect utility class.
java.lang.IllegalStateException: Couldn't clone property 'org.eclipse.elk.junctionPoints'. Make sure it's type is registered with the ElkReflect utility class.
at org.eclipse.elk.graph.properties.Property.getDefault(Property.java:140)
The error above happened when trying to convert the graph to a JSON. The same message occured, but with "org.eclipse.elk.nodeLabels.padding" instead of "org.eclipse.elk.junctionPoints", when trying to layout the graph with LayeredLayoutProvider.
This doesn't happen when I'm operating over a simple graph (5 nodes, 6 edges, some ports), but happens on a more complex graph (built by iterating over a SysML model).
How should I proceed so that "types are registered with the ElkReflect utility class", as the error message says ? Is it a dependency problem or does it have to something to do with the graph construction process ?
I'm only using basic ELK functions for constructing my graph (ElkGraphFactory.createElkNode, ElkGraphFactory.createSElkPort, ElkGraphUtil.createSimpleEdge).
Thanks in advance
Re: Unclonnable property - ElkReflect [message #1802100 is a reply to message #1802038] Fri, 01 February 2019 02:37 Go to previous messageGo to next message
In what context are you using ELK? As Eclipse plugin, or standalone Java?
Re: Unclonnable property - ElkReflect [message #1802102 is a reply to message #1802100] Fri, 01 February 2019 02:57 Go to previous messageGo to next message
I'm using ELK in a standalone Java application.
I should also mention that the environment setup is a bit peculiar, and the ELK .jar were not implicitly part of the environment so I had to import them by hand.
The simpler case I mentioned (with a small graph of 5 nodes, 6 edges) took place in another standalone Java app where the environment was more usual and the import of ELK could be done normally as ELK was implicitly part of the environment.
My understanding is that my bug stems from the fact that ELK tries to access classes that are part of the org.eclipse.elk package, however my class path only contains subpackaees such as org.eclipse.elk.alg or org.eclipse.elk.core.
This makes me think I should import the whole org.eclipse.elk package, but I can't find it anywhere. Does this mean my import approach should be different ?
Re: Unclonnable property - ElkReflect [message #1802104 is a reply to message #1802102] Fri, 01 February 2019 03:54 Go to previous messageGo to next message
You need to initialize the layout metadata service with the algorithm you'd like to use:
LayoutMetaDataService.getInstance().registerLayoutMetaDataProviders(
		new ForceMetaDataProvider(),
		new LayeredMetaDataProvider(),
		new MrTreeMetaDataProvider(),
		new RadialMetaDataProvider(),
		new StressMetaDataProvider(),
		new PolyominoOptions(),
		new DisCoMetaDataProvider(),
		new SporeMetaDataProvider()
Re: Unclonnable property - ElkReflect [message #1802220 is a reply to message #1802104] Mon, 04 February 2019 09:14 Go to previous messageGo to next message
Thank you !
Re: Unclonnable property - ElkReflect [message #1859269 is a reply to message #1802100] Thu, 25 May 2023 08:23 Go to previous message
The context using ELK : I am using ELK Eclipse plugin
i am getting the follwing issue when i try to layout my diagram.
Caused by: org.eclipse.e4.core.di.InjectionException: java.lang.IllegalStateException: Couldn't clone property 'org.eclipse.elk.nodeLabels.padding'. Make sure its type is registered with the ElkReflect utility class.
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:68)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:319)
Previous Topic:Issue with build/pom.xml
Next Topic:Pathing not aligned - Parameter to tweak
Current Time: Sun Jun 22 05:47:20 EDT 2025
Powered by FUDForum. Page generated in 0.03892 seconds
