How to determine the enabled state of a command programmatically? [message #1802036] |
Thu, 31 January 2019 08:11 |
Thomas Fahrmeyer Messages: 30 Registered: July 2009 Location: Germany |
Member |
I'm trying to bind an UI control, a button, to the enabled state of a command. The reason is, that I want to have a contribution interface (a defined command) to allow external parties to provide logic that should be executed. The button shall execute this provided logic but have to be disabled if no contribution was provided. Therefore I'd like to bind it to the enabled state of a command.
I tried it with the big code snippet at the end.
It works, if I determine the enabled state via
eCommandService.getCommand(ZOOM_CMD_ID).isEnabled();
It provides the correct/expected state every time.
My question is what is the difference between
and
eHandlerService.canExecute(getParametrizedCommand());
I'd expect that they are equal semantically. They deliver the same result if I dont leave the part and toggle the handler registration programmatically. BUT if the command is enabled and I switch to another part, the enabled state is different.
* cmd.isEnabled() is false as expected, because the handler was registered for the part
* canExecute() is still true, which is not correct in my opinion
So, to come to the end :) If someone could answer the following questions:
* What is the semantic of both approaches?
* In which use case I should use which version?
Thanks for your support
Thomas
// observes context changes. These will happen if a handler is registered for a command
part.getContext().runAndTrack(new RunAndTrack() {
public boolean changed(IEclipseContext context) {
checkExecuteButtonEnablementLongVersion();
return true;
private void checkExecuteButtonEnablementLongVersion() {
// part is the MPart containing the control (button) that should be controled by
// the enablement of a command ZOOM_CMD_ID
IEclipseContext partContext = part.getContext();
EHandlerService eHandlerService = partContext.get(EHandlerService.class);
ECommandService eCommandService = (ECommandService)partContext.get(ECommandService.class);
boolean enabledViaCanExecute = eHandlerService.canExecute(getParametrizedCommand());
boolean enabledViaIsEnabled = eCommandService.getCommand(ZOOM_CMD_ID).isEnabled();
if (enabledViaCanExecute != enabledViaIsEnabled) {
System.out.println(">>> enabled state is different!");
} else {
System.out.println("enabled state is the same!");
executeButton.setDisable(!enabledViaIsEnabled);
private ParameterizedCommand getParametrizedCommand() {
ParameterizedCommand command = ParameterizedCommand.generateCommand(
getCommandService().getCommand(ZOOM_CMD_ID), new HashMap());
return command;
Re: How to determine the enabled state of a command programmatically? [message #1802081 is a reply to message #1802064] |
Thu, 31 January 2019 22:22 |
Member |
Brian de Alwis wrote on Thu, 31 January 2019 15:56Handlers can be installed on parts, windows, and applications, whereas the commands are global. The command service updates the command enablement states based on the active part's handler service.
Ok, that is expected and wanted. In my understanding for my usecase the commandService approach is the right one. Only that gives me the command state the user would expect.
Note that you are fetching your services from the part context, so that handler service is always resolving handlers from that part.
Ok, got it :) The handlerservice instance still as the handler registered for the given command no matter whether is not active anymore from the global application point of view. If I would use the handlerservice from the perspective context, the state should be correct as well, isn't?
Thanks Brian for the explanation.
Thomas
Re: How to determine the enabled state of a command programmatically? [message #1802231 is a reply to message #1802081] |
Mon, 04 February 2019 18:38 |
Quote:The handlerservice instance still as the handler registered for the given command no matter whether is not active anymore from the global application point of view. If I would use the handlerservice from the perspective context, the state should be correct as well, isn't?
Not quite: the handler service is a service that performs lookups. Each handler service starts a lookup from its associated context.
A handler service rooted at a perspective would start its lookups at the perspective. Which isn't what you want.
What you might want is to get the active part within the perspective and get that part's handler service.
Brian.
FUDForum. Page generated in 0.03857 seconds
