Home » Newcomers » Newcomers » EPF Composer - Error with loading cheat sheet(Error loading cheat sheet content)
EPF Composer - Error with loading cheat sheet [message #1802000] Wed, 30 January 2019 14:34 Go to next message
Gavita Regunath is currently offline Gavita RegunathFriend
Hi there,
I am having a few issues with accessing cheat sheets from either the Welcome screen of from Help> Cheat Sheets - see screenshot.
The error is:
Error loading cheat sheet content.
!MESSAGE Cheat sheet content file '$nl$/cheatsheets/createmethodconfiguration.xml' not found.
Has anyone had a similar issue? And if so, would you please let me know how to solve this issue?
Re: EPF Composer - Error with loading cheat sheet [message #1806967 is a reply to message #1802000] Mon, 20 May 2019 10:07 Go to previous messageGo to next message
Ismael Olea is currently offline Ismael OleaFriend
Member
Hi:
I didn't see your message because you didn't posted in the EPF sub-forum.
I checked in my system and yes, there are only two cheatsheets packed:
ls -l ~/bin/epf-composer-1.5.2-linux/plugins/org.eclipse.platform_4.2.2.v201302041200/cheatsheets
total 8
-rw-r--r-- 1 olea olea 2715 sep 28  2018 cvs_checkout.xml
-rw-r--r-- 1 olea olea 2890 sep 28  2018 cvs_merge.xml
Never watched at the EPFC sources so don't know if it is just a packaging bug. If you wish you could fill a bug report at https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EPF
Re: EPF Composer - Error with loading cheat sheet [message #1829601 is a reply to message #1802000] Tue, 07 July 2020 13:29 Go to previous message
Jaroslav Pavlicek is currently offline Jaroslav PavlicekFriend
I experience the same. Never worked with the tool. Did download, unzip, read the doc and keen to explore it. But cannot open examples or anything.
My environment: Windows 10, version epf-composer-1.5.2-win32.zip
Previous Topic: UML plugin for Python in Eclipse
Next Topic:Failed to create the Java Virtual Machine on Mac
Current Time: Mon May 17 20:47:17 GMT 2021
Powered by FUDForum. Page generated in 0.02317 seconds
