Home » Eclipse Projects » Sirius » How to auto create unique identifier for instances?(uid identifier ID create instance set feature)
How to auto create unique identifier for instances? [message #1801815] Sun, 27 January 2019 18:57 Go to next message
Mars Keez is currently offline Mars KeezFriend
How can I automatically create a unique identifier while creating an instance?
Saw for example "Uid" in Sirius meta model elements. Looks perfect. But how to do this?
Also simpler approaches (timestamp etc) would be appreciated.
ps
been using a name attribute with "ID" property, but that's not enough for my purposes.
Re: How to auto create unique identifier for instances? [message #1801825 is a reply to message #1801815] Mon, 28 January 2019 06:24 Go to previous messageGo to next message
How unique?
If you want to differ from anything anywhere anytime, you might use EcoreUtil.generateUUID().
But if you only want uniqueness here, then you produce something much friendlier by counting similarly scoped names and then allocating a name such as scope-name-count. But you must check for collisions and move on because deletions in this or a previous edit session may reduce counts facilitating confusing re-use.
Ed Willink
Re: How to auto create unique identifier for instances? [message #1801830 is a reply to message #1801825] Mon, 28 January 2019 08:00 Go to previous message
thx!
have to give the ecore function a try then.
Previous Topic:multiple diagram elements for the same domain class
Next Topic:How to enable and disable Node from Palette
Current Time: Sat Sep 07 20:52:10 GMT 2024
Powered by FUDForum. Page generated in 0.03572 seconds
