Home » Eclipse Projects » Remote Application Platform (RAP) » RAP 3.7 and Java 11 Support(Which versions of Java are supported with which RAP versions?)
RAP 3.7 and Java 11 Support [message #1801734] Fri, 25 January 2019 11:46 Go to next message
John Gymer is currently offline John GymerFriend
Trying to run a RAP 3.7 application WAR inside FireFly 15.0.1 with various versions of Java on Windows 7 64-bit, and running into problems with any Java version beyond JDK8 (Oracle or an OpenJDK build).
What versions of Java should I expect a RAP 3.7 application to work with?
JDK8 64-bit: OK
AdoptOpenJDK8 64-bit: OK
OpenJDK9 64-bit: ERROR
JDK11 64-bit: ERROR
I've tried various other versions too, and the common factor seems to be moving beyond JDK8.
The issue I see is in resource handling and ClassLoader usage, with the pertinent part of the exception being:
2019-01-25 15:33:07,028 ERROR [io.undertow.request] (default task-2) UT005023: Exception handling request to /<myapp>/<mycontext>: java.lang.ClassCastException: class jdk.internal.loader.ClassLoaders$AppClassLoader cannot be cast to class java.net.URLClassLoader (jdk.internal.loader.ClassLoaders$AppClassLoader and java.net.URLClassLoader are in module java.base of loader 'bootstrap')
This is in calling:
URLClassLoader pcl = (URLClassLoader)ClassLoader.getSystemClassLoader();
Is this a RAP-support issue, or something I can workaround in my code by changing the way I deal with the ClassLoader? The only difference is changing from Java8 to something newer?
I want to continue to compile my code using Java8.
Thanks, John
Just because you can doesn't mean you should
Re: RAP 3.7 and Java 11 Support [message #1801735 is a reply to message #1801734] Fri, 25 January 2019 11:59 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
Hi John,
just tried our Controls Demo with OpenJDK 11.0.1 under windows and everything is working fine. Tried with JDK 10.0.2 as well.
During the development I'm testing our demos with the most recent JDK/OpenJDK in my daily basis.
I can't find in RAP sources the mentioned code:
Where this code is used?
Ivan
Re: RAP 3.7 and Java 11 Support [message #1801745 is a reply to message #1801735] Fri, 25 January 2019 15:04 Go to previous messageGo to next message
Hi Ivan,
No, sorry, this is our own code calling getSystemClassLoader() and casting to URLClassLoader, not RAP.
I wonder if this is no longer supported in Java9+ or if there is a 'new' way of doing it? I haven't investigated too far yet, as I just assumed that versions of Java would be backwards-compatible, but if you have any other experiences, that would be useful?
Thanks, John
Re: RAP 3.7 and Java 11 Support [message #1802109 is a reply to message #1801745] Fri, 01 February 2019 09:41 Go to previous messageGo to next message
Linuxhippy Mising name is currently offline Linuxhippy Mising nameFriend
Member
John Gymer wrote on Fri, 25 January 2019 10:04
Hi Ivan,
Thanks, John
For Java9' module system the class loader structure and architecture has been re-designed. Casting the system class loader to URLClassLoader was using an undocumented implementation detail, so breakage was to be expected.
Re: RAP 3.7 and Java 11 Support [message #1802260 is a reply to message #1802109] Tue, 05 February 2019 13:56 Go to previous messageGo to next message
Thanks Ivan.
I've re-written our Class Loader logic completely, as there is no direct work-around, so all is good now thanks, one of the keys being to use "Class.forName()" instead.
Cheers, John
Re: RAP 3.7 and Java 11 Support [message #1808401 is a reply to message #1801734] Mon, 24 June 2019 04:54 Go to previous message
Josh Mo is currently offline Josh MoFriend
I am using the old version of RAP (version 1.3). Is the new version (version 3.9) compatible for the old version, so that I don't need to make any changes to my code?
Josh
Previous Topic:SIze of screen
Next Topic:RAP compatible for the older version
Current Time: Mon Oct 25 11:09:31 GMT 2021
Powered by FUDForum. Page generated in 0.01858 seconds
