Home » Archived » Orion (Archived) » Code Map Ruler?(Where is it?)
Code Map Ruler? [message #1801727] Fri, 25 January 2019 10:57 Go to next message
Pablo  eltrán is currently offline Pablo eltránFriend
I've embedded Orion Editor by following these instructions and it looks and works great!
http://planetorion.org/news/2013/02/embed-the-latest-orion-editor-in-your-code-in-2-steps/
Now, I want to show the Code Map Ruler.
What is it (plugin?, etc) and where can it be found?
I've searched for "code map" and similar in the code without much success.
Pablo.
Re: Code Map Ruler? [message #1801781 is a reply to message #1801727] Sat, 26 January 2019 16:50 Go to previous message
I meant showZoomRuler instead of "code map ruler". It seems like OrionHub uses its own nomenclature...
I'm able to run the
/examples/editor/demo.html
from my test environment and show and hide the zoom ruler from there.
However, it looks like the property "showZoomRuler" does not work with
/built-editor.js
nor
/orion/editor/edit.js
I've even modified the sources to ensure that "true" value is set to avoid any configuration issue.
I also ran the
/orion/compare/examples/demo.html
to compare files. It works fine. However, once again the
/built-compare.js
does not work (The "Compare" parameter is always undefined). Just the same happens when
/orion/compare/examples/standalone/demo.html
is executed.
IMHO, someone at this project should check whether the documentation and all the examples really work as described.
Many parts work. But others.....
Previous Topic:Orion WAR does not work
Next Topic:Change front-end UI Orion
Current Time: Wed Feb 21 04:50:44 GMT 2024
Powered by FUDForum. Page generated in 0.02752 seconds
