Home » Eclipse Projects » NatTable » How to disable the empty vertical scrollbar painting(if no row data is defined)
How to disable the empty vertical scrollbar painting [message #1801667] Thu, 24 January 2019 12:55 Go to next message
Hilger Steenblock is currently offline Hilger SteenblockFriend
How to disable the empty vertical scrollbar if no row data is defined? In this case an empty vertical scrollbar is painted.
Any idea how the vertical scrollbar can be hidden in this case ? I tried following without success:
natTable.getVerticalBar().setVisible(false);
natTable.getHorizontalBar().setVisible(false);
Example to reproduce: _5111_ColumnGroupingExample.java and set the number of persons to 0.
Re: How to disable the empty vertical scrollbar painting [message #1801696 is a reply to message #1801667] Thu, 24 January 2019 20:27 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
This is a regression introduced with the fix for
Bug 538321 - [Freeze] Scrollbar should not vanish if window size is change
I corrected it so it should work correctly again with the latest SNAPSHOT by still having the original fix in the freeze usage
Re: How to disable the empty vertical scrollbar painting [message #1801739 is a reply to message #1801696] Fri, 25 January 2019 12:25 Go to previous message
Thank you so much.
Previous Topic:ComboBox Multiselect/Use Checkbox question
Next Topic:ColumGroupHeader-Styling Issue
Current Time: Mon Dec 16 05:50:25 GMT 2019
Powered by FUDForum. Page generated in 0.02866 seconds
